Multiple ECU Codes?
Old Apr 3, 2009 | 06:41 AM
Niccos89's Avatar
Multiple ECU Codes?
How does the ECU go about multiple codes at the one time, will it display them one after the other, or one at a time until the code is cleared, before displaying the next?
I've never had more than one code, and my ECU is currently throwing this pattern:
Red/ Long x 1
Green/ Short x 2
Which I pressume is 12, Air Flow Meter / Circuit Open/Short
THEN
Green/ Short x 4
THEN
Green/ Short x 4 or 5
THEN Green/Short x 5
About 3 second intervals, before repeating itself.
I was about to change oil today, thinking that the heavier weight oil I used wasnt right for the recently lower temperatures, but decided to check the ECU before I went ahead, since I clicked the screw back, its now Idling even lower (P / N = 500 RPM, R/D/2/1 = 300-400 RPM (No Stalling)). It was, otherwise behaving normally and running great.
Old Apr 3, 2009 | 09:18 PM
Niccos89's Avatar
UPDATE:
Checked and cleaned MAF Sensor and connections, no avail.
Reset ECU and set idle rpm to mid-high range, took it for a lap around the block and codes 4, 4 and 5 returned. Again reset ECU and another lap around the block, codes gone.
Idle RPMs are now
P/N: 1300 gradually lowers to 900
R/D/2/1: 700
Regardless of temperature, putting it back into P/N will see it go back up to 1300 and gradually drop down...is this normal?
Another odd thing I noticed, just out of curiosity, checked my battery, getting 12.8 on idle, and 13.8 - 14.0 when revved up....
Since I got the car, its been a lazy-SOAB at holding charge....even 10 minutes of stereo on, or 5 minutes of park lights and it decides its too hard to try and crank the engine......is this perhaps the cause of my idle problem?
TKHanson
Nov 24, 2018 01:39 AM
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
