Revolution sensor error
Old Apr 4, 2009 | 04:06 PM
gfnk357's Avatar
I'm getting the code for a revolution sensor problem when I do the self check diagnostic. I checked the sensor and the resistance was within spec (it was 592 ohms, spec is between 500 and 650). Could the revolution sensor be bad even if the resistance is fine or do I need to start checking harness wires for continuity?
Old Aug 19, 2009 | 01:42 PM
93maximaguy's Avatar
im having the same problem on my 93 ve auto. my sensor read 610 ohm but the TCM says its bad so what now?
Old Aug 20, 2009 | 01:10 PM
bump no one can help?
Old Aug 20, 2009 | 01:27 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
do you have a multimeter with a long enough wire to test the continuity of the wire FROM the sensor TO the TCM?
Old Aug 20, 2009 | 01:37 PM
no i dont but i could make something up to do it
Old Aug 20, 2009 | 06:40 PM
burhan92SE's Avatar
Unplug the TCM's big harness and clean it with electrical cleaner....sometimes its dirty and signal isnt getting through....plus clean the TCM pins as well and while u r there u might wanna do the same thing to ECM....
Old Aug 20, 2009 | 07:02 PM
kk. basically you're checking for a potential broken wire in the harness... which if there is, i would just cut that individual wire about 4" down from the plug, make sure it had continuity for those 4 inches on each end (sensor side and tcm side) then just use 2 wire splice and run a long wire from the TCM harness wire, under the carpet, behind the kick panel, around the front of the door by the hinges, thru the fender, and up into the engine bay to the sensor.
Old Aug 21, 2009 | 08:44 AM
i might have a friend with a multi-meter that has long leads but it has to wait untill i get a day off work. also it seems to come and go so it sounds like a bad wire
Old Aug 24, 2009 | 11:13 AM
gfnk357's Avatar
does anyone know if these sensors are supposed to be checked hot or cold? I can't find anything that specifies in the FSM. I checked my sensor a couple more times and it reads out of spec when hot and in spec when cold.
Old Aug 24, 2009 | 12:45 PM
internetautomar's Avatar
mod or sell?
the revolution sensor should ALWAYS read in spec whether hot or cold.
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
