Correct belt sizes for the ASP UDP for a VE
Old Nov 21, 2001 | 11:50 PM
Aaron92SE's Avatar
NWP Engineering.com
These are the correct Gates belt sizes:
A/C Gates K040460
Alt Gates K050323
P/S Gates K040378
I went to Pep Boys and got the manager to convert the Gates belts to their brand, Dayco. Here are the Dayco sizes:
A/C Dayco 460K4
Alt Dayco 325K5
P/S Dayco 378K4
The A/C and Alt belts that ASP gives you are correct. But, the P/S belt size ASP gives you is wrong. Go with the P/S belt size I used. Hope this helps.
Old May 21, 2003 | 07:53 PM
GReDdyXMaXiMa
If i get the pulleys and it requires to get different sized belt for the pulleys when the stock comes off ? I'm planning on gettin RPM pulleys , if that so then is it all information that u ve said will do the same thing about the sized of belt?
Old May 21, 2003 | 08:43 PM
Aaron92SE's Avatar
NWP Engineering.com
huh? Please rephrase your question. No other company that I know of makes a pulley for the VE other than ASP and RVM (brand new company and not as good as ASP from what I hear).
And just so you know... you can't get a set of pullies for the VE; just a crank pulley.
Old May 21, 2003 | 09:38 PM
GReDdyXMaXiMa
I know .What I'm saying is that I m planning on to get the CRANK pulley from RPMoutlet.com and is it possbile to reuse the same belt or i ll have to get new one w/ different size of belt?
Old May 21, 2003 | 10:07 PM
D-sta's Avatar
Well if you have a stock crank pulley which I think you do, you will most definitely have to buy new belts for the ASP UDP you are buying from www.RPMoutlet.com The belts you need to use are the ones Aaron provided above.
Old May 21, 2003 | 10:08 PM
todamax's Avatar
The belts that Aaron92SE posted are correct for the UDP, I used a slightly smaller P/S belt. It was a ...77 and it works fine.
Old Jul 10, 2003 | 04:03 PM
crazy4maxima's Avatar
whats the size of the upd belts for goodyear.? any other belt companies are good?
Old Jul 10, 2003 | 05:17 PM
JTMAX03's Avatar
If you give the parts store the gates belt size they convert it for the goodyear belts.
Miket2006
Mar 1, 2021 03:55 AM
knight_yyz
Nov 1, 2015 01:34 PM
leatherneck
Sep 30, 2015 09:16 PM
homewrecker
Sep 24, 2015 07:01 PM
