help unclogging moonroop drainage pipe
Old May 8, 2009 | 11:05 AM
john402052000's Avatar
After rains recently water would spill onton the passenger seat when I came to my first full stop. I assumed the moonroof was leaking but, after searching the forums found that the culprit is a clogged drainage pipe/hose. The tip of this comes out behind the rear passenger tire. My question is: how do I access this so I can unclog it? The thread I found:
http://forums.maxima.org/3rd-generat...da-storms.html
doesn't have the photos linked any more so I can't figure out how to do this.
Any help would be great.
thanks,
John
Old May 8, 2009 | 11:12 AM
Greeny's Avatar
¯\(°_o)/¯
moonroop?
anyhow I'm pretty sure you can use a metal coat hanger to clean out the drain hose passage, just cram it up in there..
Cars are alot like women in some ways..
Old May 8, 2009 | 11:56 AM
AEMAXIMA01's Avatar
Compressed air works as well. That's how I cleaned mine out.
Old May 8, 2009 | 12:13 PM
cardana24's Avatar
Blown
I had this problem recently, and I think I was spraying out the right thing. I had a hole on either side toward the front of the moonroof opening, so I shot compressed air down that. But to me it sounded like it came out behind the front tires. Am I wrong?
Old May 8, 2009 | 12:21 PM
Greeny's Avatar
¯\(°_o)/¯
The drain hoses are on the rear of the sunroof unit, they run down through the c pillars on each side of the car, exiting out by the rear mudflaps..
Old May 8, 2009 | 12:23 PM
Greeny's Avatar
¯\(°_o)/¯
http://www.courtesyparts.com/maxima-...1724_1739.html
Old May 8, 2009 | 12:34 PM
Greeny's Avatar
¯\(°_o)/¯
oh my, it has front ones also..
learn something new everyday..
Old May 8, 2009 | 12:46 PM
After I started this thread I poked around the trunk and found I could access the tubes via the jack compartment. I unhooked the black tube and it had a bunch of gunk in it, including those helicoptor seeds. Anyway, I thinks its clear.
Are you able to access the front of the tubes via the moon rooF?
thanks,
John
Old May 8, 2009 | 12:50 PM
DanNY's Avatar
Ad·min·is·tra·tor
these damn n00bs
Old May 8, 2009 | 01:36 PM
cardana24's Avatar
Blown
thanks,
John
yeah. Open it all the way and you will see a hole on either side about the size of a dime. Hook up you air attachement on your compressor and blow the lines out.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Quickywd01
Sep 21, 2016 09:36 PM
