exhaust manifold gasket and/or intake manifold gasket
May 25, 2009 | 05:31 AM
well im starting on my injector change{93 gxe} but i wanna kno do i have to change both of these because the intake manifold gasket is $56 and i dont wanna spend it if i dont have 2. also i used a small screw driver and wedged it on the side of the injector and popped it out in no time{rail from junk yard} i know some ppl say they catch hell getting thenm out of the rail. ANY TIPS ON THE JOB WOULD BE VERY APPRECIATED!!!!!!!!! thnx
May 25, 2009 | 06:02 AM
you only need the plenum gasket when doing injector changes
May 25, 2009 | 07:23 AM
$56 from who ??
May 25, 2009 | 07:43 AM
You must be talking about the bottom intake manifold gasket for $56. You will not remove the intake manifold, so you do not need that gasket. Do replace the upper gaskets, one is $3 and the other $11. You'll also need two o rings (large and small) for each injector removed. Double check whether you have yellow or green dot injectors prior to buying replacements.
Might I also suggest replacing your left hand rocker cover gasket (cylinders 2,4,6) since the upper intake manifold collector will be removed. It's a pain to get to, and since everything will be off, best do it now, even if it isn't leaking.
Good luck.
May 25, 2009 | 03:41 PM
Quote: You must be talking about the bottom intake manifold gasket for $56. You will not remove the intake manifold, so you do not need that gasket. Do replace the upper gaskets, one is $3 and the other $11. You'll also need two o rings (large and small) for each injector removed. Double check whether you have yellow or green dot injectors prior to buying replacements.
Good luck.
i dont know what a rocker cover is but as far as the injectors go im taking them out 2 morrow didnt feel like bothing with it today, i cant see the dots i guess they faded away so ill try 2 look harder when i pull them out. im gettin the replacemwnts from the junk yard because i bout red tops which was wrong so im getting pink tops now... i just need it 2 work for a a couple months then ill try 2 replace all 6 with brand new ones. thnx 4 the info guyz!!!!!!
May 25, 2009 | 04:02 PM
Quote: i dont know what a rocker cover is but as far as the injectors go im taking them out 2 morrow didnt feel like bothing with it today, i cant see the dots i guess they faded away so ill try 2 look harder when i pull them out. im gettin the replacemwnts from the junk yard because i bout red tops which was wrong so im getting pink tops now... i just need it 2 work for a a couple months then ill try 2 replace all 6 with brand new ones. thnx 4 the info guyz!!!!!!
yeah definitely don't use red tops. i made the mistake of convincing myself "aw it'll be alright" and now i'm struggling to get 200 miles out of a tank of gas (used to get 400-450mi per tank), and my engine makes mischievous noises at startup.
rocker cover = valve cover (red metal things that cover each bank of cylinders' heads. the rear rocker cover is where your oil fillernck is)
May 25, 2009 | 04:48 PM
oooh ok lol
