VG Header/Ypipe
Old Jun 8, 2009 | 02:13 AM
CMax03's Avatar
VG Header/Ypipe
Almost complete!!! Need my two(O2) bungs welded on and rear flex section welded in place...temporary fitment clamp!
Old Jun 8, 2009 | 03:40 AM
Looks pretty good. Where are those headers?
Old Jun 8, 2009 | 06:14 AM
internetautomar's Avatar
mod or sell?
1. why the flex section on the front section? it should NEVER flex separately from the rear section.
2. You should have used a longer flex at the rear. The shorter flex doesn't have the play these motors need to keep from destroying it.
Old Jun 8, 2009 | 10:13 AM
CMax03's Avatar
Oh, no that's covered.... engine mounts are poly filled! and that's a 6 inch flex plus the ball socket joints @ the headers!
Old Jun 8, 2009 | 12:34 PM
mod or sell?
good luck.
WSP once upon a time offered ball socket joint in place of the flex. They stopped doing it because of exhaust leakage.
I would still recommend a longer flex section.
Old Jun 9, 2009 | 12:07 AM
CMax03's Avatar
Right here!!! I've shown them B4. I measured my flex flexibility and it can flex more than 35 degrees total. Those polyurethane filled mounts aren't gonna give that much movement either...believe me bro it's all been covered! The little flex section was installed so once I loosely fit the flange bolts at one header I would have a little movement in the other downpipe if I needed to adjust anything....
Old Jun 9, 2009 | 12:55 AM
maximo018's Avatar
FINALLY! Naw I'm just screwing with you. It looks great/ now get those O2 bungs and put that damn thing in already.
Old Jun 9, 2009 | 01:09 AM
CMax03's Avatar
Go 2 bed! It's pass your bedtime....you Maxima.org vampire.
Old Jun 9, 2009 | 09:42 PM
maximo018's Avatar
Actually I didn't fall asleep til 7 this morning.
jd87sep
Dec 30, 2012 10:28 PM
MikeSDA
25
Jun 3, 2007 07:07 PM
