What color are my injectors? and what is that cap called that screws down on top?
Old Jun 25, 2009 | 02:51 PM
92maxima92's Avatar
What color are my injectors sopposed to be?? I called the guy at the nissan dealer and he said they have blue or black and my injectors are red?? And what is the cap called that screws down on top of the injector to the fuel rail??
Old Jun 25, 2009 | 02:58 PM
Greeny's Avatar
¯\(°_o)/¯
They are red.
The cap is called a "Injector top cap"
The dealer is looking at VG30E injectors, they have a blue/black dot on them,
Make sure you specify you have a VE30DE engine when buying parts.
Old Jun 25, 2009 | 03:06 PM
92maxima92's Avatar
I cant find the injector top cap anywhere?
Old Jun 25, 2009 | 03:08 PM
Greeny's Avatar
¯\(°_o)/¯
You mean you lost your cap?
Old Jun 25, 2009 | 03:52 PM
92maxima92's Avatar
no i Cant find them online to buy. two of mine broke when i was trying to install the injectors.
Old Jun 25, 2009 | 04:22 PM
James92SE's Avatar
2 VE's are better than one!
How in the world can you break the top cap?
Old Jun 25, 2009 | 04:29 PM
Greeny's Avatar
¯\(°_o)/¯
how in the world did joo break the cap mang?
I have some extras if you want them, cheap
Old Jun 25, 2009 | 06:16 PM
92maxima92's Avatar
How do you get the injectors in the rail easily?? Can you use a different lube than gas on the top big oring on the injector to get it in the rail? I just screwed the cap down little by little to get the injector in the rail and it pinched the orings again and broke the two caps. Whats the trick to get the injector in the rail easily??
Old Jun 25, 2009 | 06:22 PM
Greeny's Avatar
¯\(°_o)/¯
Yeah dude, you got to lube up both upper and lower o'rings with Vaseline before installing them into the rail..That's why you have been pinching o'rings..
I still fail to understand how you broke the injector caps..
Old Jun 25, 2009 | 07:19 PM
johnno890's Avatar
do you mean the pintle caps on the bottom where the little o ring is??
Old Jun 25, 2009 | 07:29 PM
92maxima92's Avatar
If i lube it will the injector just push into the fuel rail?? and will the vaseline effect my gas cause it will get in it?? I broke the injector top caps because i couldnt get the injector all the way(no lube) in the rail so i just started screwing it down little by little switching screws and it broke.
Old Jun 25, 2009 | 08:01 PM
BenStoked's Avatar
Jesus was a Zombie.
there is a LOT of pressure coming out of those injectors, enough to push any vaseline (I believe they mean the petroleum jelly, not the hand moisturizer creamsm to make sure that is clear)out of the injector tip, and burn off somewhere in the engine. any "negative" consequences of using it will be gone a few seconds after running the newly installed injectors.
Old Jun 25, 2009 | 09:11 PM
nitrous360's Avatar
I believe he broke the metal covers on the fuel rail trying to crank them in.
Old Jun 26, 2009 | 05:50 PM
internetautomar's Avatar
mod or sell?
I believe most later nissans use the same metal tops.
captchaos
Mar 15, 2016 12:18 PM
minsbang
Sep 11, 2015 08:48 PM
Maxima.KsA
Sep 8, 2015 11:33 PM
dcam0326
Sep 7, 2015 07:26 AM
