question about reserve radiator tank
the other day i changed my battery and i noticed that the reserve radiator tank overflow hose wasint connected to anything i looked for the spot its supposed to connect to but i cant find it ,is it supposed to be like that so it spills out just in case. thanks if you know.
i think the design depends if you have abs or not. like mine (non abs... so, on the passenger side) has a 90-degree vent hole at the top, and then the hose fitting on the side that wraps underneath.
true, my GXE was different I guess... tank is side mounted to the battery tie down bracket now and has a angle cut hose aimed down into the engine.
ABS FTL, just picked up a new actuator (thingy with the steel lines coming out of it) - looks fun to install. Mine is leaking out of the valve body :-X
![Frown](https://maxima.org/forums/images/smilies/frown.gif)
NERDJUSTBNME
09-30-2015 03:20 PM
RWCreative
09-21-2015 11:01 AM
