Performance Ignition Wires
Re: Performance Ignition Wires
Originally posted by Takumi
I have a 93 SE with a electronic ignition and i was wondering where i may find some performance wires for that?
Re: Re: Performance Ignition Wires
Originally posted by DA-MAX
Ummmm, I'm pretty sure the VE engine doesn't have ignition wires.....
They say HKS has a Twin Fire box for coil-less ignitions, but I can't see what good it can do.
Re: Re: Re: Performance Ignition Wires
Originally posted by maxmizd27
You are correct sir! It does not. Each cylinder has it's own ignition coil sitting directly on top of each spark plug. Took me a while to figure out why I couldn't find any either.
Re: Re: Re: Re: Performance Ignition Wires
Originally posted by Aaron92SE
MDS makes an ignition box for our VE's.
Re: Re: Re: Re: Re: Performance Ignition Wires
if you are reffering to the Stacker I think there are some wiring issues with the Maimxa and its coil packs.....
Re: Re: Re: Re: Re: Re: Performance Ignition Wires
Yeap, the Stacker Series Ignition Boxes. I believe MSD has another box that's not Stacker. It's just a regular distributorless ignition box. I'm wondering if it helps the VE's.
Re: Re: Re: Re: Re: Re: Re: Performance Ignition Wires
yeah, rumor was a few months ago this 5th gen guy hooked up a Stacker, turned out to be BS though...the wiring just doesn't go! and also the othe MSD DIS units don't work on a VE Max either, usually only 4cyl(2-4 coil), vehiles and some of the new V-8 stangs(Jacobs DIS)!
Just so I get this straight: There aren't even any brightly coloured ignition wires for VEs?
That sucks because it's always nice to add just a little flash under the hood. I don't suppose those kits where you make your own wires would work either because of the different boots on the ends right?
Derrick2k2SE
Nov 19, 2015 10:14 PM
Dasmith
Sep 23, 2015 08:28 PM
Keyno McMike
Sep 21, 2015 07:18 AM
