Removing yoke from striking rod
What is the trick here?
I've got the pin out, but the darn thing won't budge at all. Not in the least. If I didn't know any better it almost seems as if the darn thing is all one unit, but I know with the pin out the yoke should be able to come off
I'm attempting to replace the strike rod seal but I can't do that if I can't get the darn yoke off.
i have to concede complete and total failure on this one.... i never got the f*cker to come off. thus i've just been topping off my tranny fluid every couple weeks for the last 10 months. I would suggest either trying heat, or if you have a spare yoke (or if you buy one) you can just CAREFULLY use a grinder to split the stuck one in half, clean up the end of the rod, then put the new one on.
matter of fact i STILL have the brand-new striking rod seal in my toolbox as of earlier today.
I just went mid evil on mine and took it off with brute force. The only thing on that end you're going to hurt is the seal, and you're replacing it anyway.
I'd try some heat and channel locks to twist it first. see where that gets you.
Well, I tried heat last night and it didn't help at all. I've actually been working on trying to get it off for several days now (off and on when I have a few minutes here and there), and it hasn't seemed to budge one bit.
Last night I used my Bernzomatic torch and heated that MF'er up pretty good and it still didn't help at all.
Matt, how did you use brute force? What I've been doing is sticking a bar through the two holes in the yoke and trying to break it loose that way
iirc you said something on my thread about 'backing it up with a sledge then something something with a ball-peen hammer"... i didn't entirely understand what you meant nor did i ever try it, so how does that work again?
Well, I cut the yoke in three separate places down to the strike rod. Then I used screwdrivers to wedge in it and twist/prod it to get each cut to open up a bit. Then I used my torch on it several times and only then was I able to get the yoke loose enough to be able to spin/twist on the strike rod. I fear I'm still not close to getting the darn thing off
But yes, it will spin now, but the thing is still reallllllly on there pretty tight. I might be able to knock it off with a rubber mallet or something, but it's looking like I'll probably have to cut some more notches in it. What a total PITA. I wonder if the new one is gonna be impossible to get on..
No, I got it where it will spin. Well, "spin" is kind of a lenient word, as when I say "spin" I mean "get it to turn with a great deal of effort"
Well, I finally got it off. What a total PITA. I couldn't imagine trying to do this on the car
Hectic, you have a spare yoke? I already ordered one from Courtesy
my03maxima
Jul 28, 2024 07:40 AM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
