* Poll (sort of): Stock tranny life question.
My 91GXE has about 138k miles on it and still going strong. This is a good reliable car, clean inside and out, and in great shape overall. I've kept it mostly stock (see sig) and it has been gently driven all the years it's been with me (since '95). I just put new brakes on it all around and would like to keep it for several more years.
I'm concerned about the transmission though. No real reason, but a major repair like this would sour me on the car quickly. I just shelled out $3600 for a new tranny for my '95 but the reasons for that are obvious (see sig). The '91 runs smoothly, shifts normally, and doesn't complain or slip or anything else that would indicate anything other than all is well.
But I have to ask: How many miles did you get out of your tranny? Is your car modified? How hard was the car driven? Also, how much did a new tranny cost you?
Jim
Jim
Re: * Poll (sort of): Stock tranny life question.
Jim
Jim
Get a tranny cooler to be on the safe side. I'm sure you've seen all the posts about them. It can't hurt and it's about $50 or less
Ours lasted 180k miles before we had it rebuilt and that was since it was bought new back in 1987. We did all the 60k ATF changes, I guess that is why it lasted so long. Usually the tranny will give you about 5-15k miles of bad running before going completely dead. If that happens just rebuild the stocker for $1000-1500 and keep on motoring.
My maxima that I own has 198000 miles on with a used engine put in at 182000 but the transmission is still running strong had the fluids changed and a system done in the recent years. The car is stock. It is an Automatic.
Jim
Jim
My 90 GXE has 95,000 and the tranny is jerky at shifting. Is that normal? anyone know? I don't believe I have a cooler but when driven for a while (about an hour) the tranny shifts better. I changed to Mobil 1 synthetic a few months ago and didn't notice any improvement. I heard a lot people talking about Redline. any one know if changing to Redline will help shifting? That's the only thing I hate about my Max. Other than that the car is real smooth. Thanks for any comments
Is your power switch on?
It seems like a dumb question, but mabye you've just overlooked it. Check the power switch next to your coin holder to see what it's set to. If it's on power, then it's obviously gonna shift a bit harder. Mine is set on power and I have noticed that it shifts hard when it's still cold (and usually in a low gear - i.e. 1st -> 2nd). If it's not supposed to shift hard when the power switch is on, I think I may be in trouble. Also, if the person who had it before you (asuming you bought it used) drove it hard or shifted from Reverse to Drive without coming to a complete stop, then he's warn the tranny down. Only one solution - rebuild. Unless of course the damage is minimal.
Re: Is your power switch on?
I think it really depends on how well it was maintained, and the driver. Mine has been to hell and back without major problems yet. Since I only have 125K o my car it's still young, but for what it's been through(3 or 4 6K RPM neutral drops, 1.5 years of autocrossing with torque braking starts, and my very heavy foot) I'm supprised it hasn't blown up yet.
By the way my car is for sale if anybody is interested
By the way, my car is for sale if anybody is interested
Gamezilla, I tried different modes and didn't really notice the difference between power & comfort so now I just leave it at normal mode.
I drive fast on highway but very easy on the car at accelerating or slowing down. that could be the reason why the tranny hasn't died on me yet. or the way it is right now could be something very simple (I'm optimistic here) that can be fixed easily. any more comments?
...But I have to ask: How many miles did you get out of your tranny? Is your car modified? How hard was the car driven? Also, how much did a new tranny cost you?
Jim [/B]
Jim [/B]
My car is not modified, and I don't drive it hard. Just in a lot of stop and go traffic. Hope that helps!
ok... i have a 90 stock maxima with 192k on it. if u get your tranny checked now, have them run a magnet through it. if they find metal chips in it, you should replace your torque converter. and if there is excessive damage to your clutch cavity caused by the metal chips being pushed out of the torque converter which eats away at the walls in the clutch cavity will lower pressures making it impossible to shift out of 2nd. im getting mine fixed as we speak, its costing me $2300, so u better get yours checked before its to late.
and for you others, the strong shifting could also be caused by a loose wire above the transmission which lowers the pressures in the clutch cavity allowing smoother shifting. if it is dissconnected the pressures will rise, and make shifting harder.
I bought my car at an auction, completely oblivous to what a Maxima was, and the tranny went out about a week later, at about 155k miles. The replacement cost 1000 bucks (400 for the tranny + 600 labor) which was a total rip off, and I had to wait FOREVER for them to do it, and to top it off, the replacement was also junk. Luckily it was under warrenty, but still...you'd think they'd test that sort of thing.. When I rule the world, cars are going to move with magic, instead of trannies. And auto mechanics will be hooked up to lie detectors whenever they tell you something about your car.
my tranny
me and my bother and law brought maxima's he brought a 90 se
and i brought a 93gxe he's tranny went at 100,000miles and mine was slipping around 105,000 we both had them rebuilt for around 1,100 i hope they last at best a few years
pears
Sep 18, 2015 05:25 AM
pktaske
Sep 4, 2015 08:40 AM
