Piston to bore clearance
Old Sep 16, 2009 | 06:09 PM
1993-VG30E-GXE's Avatar
If the standard BORE Inner Diameter is within spec, and the standard PISTON SKIRT Outer Diameter is within spec, but the piston-to-bore clearance exceeds the 0.0014" limit, can I only replace that piston with an oversize new one to compensate, without re-boring, and without touching the other holes?
Old Sep 16, 2009 | 06:31 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
this should probably be in the all-motor section
Old Sep 16, 2009 | 06:42 PM
Here's what confuses me, the guy says he hot tanked it then measured the clearances, then he honed it. Then he calls me and tells me that the clearance is off by 4 thou, so it needs to be re-bored. But WHY would he hone it and charge me $60.00 if he knew the pistons were un-usable, as now I have to pay for the re-bore on top of the honing, which the honing will just be wiped out once they re-bore.
Very confusing.
Old Sep 16, 2009 | 07:28 PM
LvR's Avatar
LvR
HUH? - mutually exclusive IMO
FSM EM94 ............ these things run in pairs based on "grade 1,2 or 3" - what did you start with that was "in spec"?
Old Sep 16, 2009 | 07:36 PM
Both are in spec but there is a 0.0079" wear limit that exceeds the spec so the clearance can then be off.
Old Sep 16, 2009 | 07:42 PM
LvR's Avatar
LvR
I still don't get it.
What combination ito those grades did you have that was "in spec"? - if you had any combo of piston and barrel spec "in spec" (as per those grades) you cannot possibly have exceeded a wear limit
Old Sep 16, 2009 | 07:46 PM
Very confusing.
did you pick a shadetree shop? or a big-name shop? that can make a difference in terms of a) their skills and b) their honesty
Old Sep 16, 2009 | 08:20 PM
Matt93SE's Avatar
STFU n00b!
you usually can't tell if the block needs to be rebored until you hone it and take measurements. usually there's a lip at the top from old ring wear that must first be removed, then they will 'dingle ball' hone the block to remove the scratch marks and prep the surface.
Only then can they get a true measure of the bore and determine if it needs to be bored out or not.
If you're at 0.004" over already, you're halfway to the next size OEM piston. at 87.25mm
Old Sep 16, 2009 | 09:20 PM
It's not the grades, it's the piston-to-bore clearance that can be off, even though one of the other 2 is within spec, for that specific piston grade. Because at the upper limit of the bore I.D., there is lee way to the maximum wear limit - although it's within UP TO the maximum, it will then throw off the piston-to-bore clearance becasue the gap exceeds 0.0014".
I'll re-measure tommorow when I pick it up, I'm taking it to another shop, I'd rather pay the original 2 gino's that I was going to go with.
Old Sep 16, 2009 | 09:26 PM
This shop was marketed pretty good, they've been in business for 35 yrs, and the guy seems pretty competent, but it does seem a little sketchy in that building when I actually arrived. It's really tucked away in some industrial wasteland area.
They have some lifts and this sketchy looking mechanic doing something on an old car and he was smoking a Alfred Hitchcock pipe. I was really only using it for the hot tank and honing, so I figured - chance it.
Old Sep 16, 2009 | 09:32 PM
By the way what does this mean matt - for the Piston Ring Set:
1.5x1.5x2.8
This is the one I ordered - and will it fit the .50MM oversize piston's I have access to new? I don't have access to the 0.25MM oversize. pistons, so I need to go for the 0.50MM ones.
OH ****E - does this mean I have to REPLACE the radiator, if I move to the 0.50MM oversize, because the OEM radiator might not be able to handle the added heat?
Old Sep 16, 2009 | 10:02 PM
LvR's Avatar
LvR
I must surely be daft then.
What did you measure that originally was "within" spec as per your first post? - this is what I don't get.
Its absolutely no use trying to get to a "new state" 1.4"" piston to bore gap with additional honing on a worn motor if your wear limit on the bore is already (?) approaching 7.9"" - it simply cannot be done - why would you even have considered only honing it if that is what you already knew?
Matt is 100% correct about the rebuild procedure to be followed, but I am struggling to understand why the net result you now have is so confusing to you.
Old Sep 16, 2009 | 10:34 PM
LvR's Avatar
LvR
Very confusing.
4"" off from what? - the std "new" condition spec of 1.4""? ...................... if so then what the heck are you doing with looking at a 2nd oversize rebore and set of pistons? - you are still way within the 7.9"" wear spec of the bore.
Reuse the current std pistons and fit a new set of rings and BOB's surely your uncle - no?
Old Sep 16, 2009 | 10:39 PM
I'm not sure what your asking bud - but I think I have it all resolved right now. My only concern is the radiator though.
I'm definately picking up the block to bring it to another shop tommorow though, or i take it to the shop of my machinist friend's friend. I need to get a move on though, it's already getting cold in Canada now, and i'm running out of time....im such a procrastinator some times.
Old Sep 16, 2009 | 10:43 PM
He's claiming that the piston-to-bore clearance is 0.004" on one or more of the holes. He claims that I shouldn't exceed 2 thou. The actual limit for the VG30E is 0.0014"
I'll re-measure myself tommorow when I get it home and see what's up.
Old Sep 16, 2009 | 10:47 PM
LvR's Avatar
LvR
This is exactly what I don't get from all the "facts" you posted here - IMO there is absolutely no need to rebore when the honed bore to piston clearance is close on 4"" within the max wear limit of 7.9"" for the bore spec as per FSM .................... and even less a need to rebore to a 2nd oversize if that block is still in such good condition unless you have money to waste
EM94 FSM says the assembled std piston to bore gap should be 1.4"" ....................... it doesn't spec the "worn engine gap between the bore and piston" because there can be no such measurement other than the max wear limit for the bore which happens to be given as 7.9"". You cannot possibly strive for a 1.4"" piston to bore gap on anything other than a brand new engine with absolutely no wear on any component
Old Sep 16, 2009 | 10:52 PM
Let's see after I measure it. I'll post the results. He says he can just knurl the pistons (after I told him I don't want to pay him any more than the original $90.00 for hot tank and hone) ...but as far as I know it's just a band-aid.
Old Sep 16, 2009 | 10:57 PM
LvR's Avatar
LvR
IMO you need to get the honed block and FSM to a reputable machinist that can read and not suggest arbitrary thumb-suck (however close) specs for rebuild criteria on a piece of machinery that IMO is still in a pretty good state of wear given its mileage.
Old Sep 16, 2009 | 11:00 PM
Ya that's why I think i'm going to take it to my machinist friend's friend, who he worked with for 15 yrs, and i'll print out the specs. Only reason why I didn't go to him in the first place is because he didn't have the caustic tank, he used some biodegradable friendly environment stuff - which I wanted the absolute worst corrosive nasty for the environment stuff. Supposedly from calling around, about half the shops in Toronto still use the caustic.
Old Sep 17, 2009 | 04:54 AM
Matt93SE's Avatar
STFU n00b!
Again... You're discarding the advice of highly experienced and talented mechanics in order to try and do things yourself. You have absolutely NO CLUE what you need or what you're doing- all you can do is quote numbers from a manual. It's time to pay the professionals to do their job.
Drop the block off at the shop (my recommendation is to leave it at the shop that it's at now). tell them what you want in it. leave the block with them and leave it up to them on how to achieve the final results you want.
Old Sep 17, 2009 | 05:05 AM
BenStoked's Avatar
Jesus was a Zombie.
if the spec is out on grade 1, go to grade 2, or grade 3. not difficult concept.
Old Sep 17, 2009 | 05:07 AM
LvR's Avatar
LvR
Glad you think that helped at all....................... ever heard of manufacturing tolerances yet?
Old Sep 17, 2009 | 08:11 AM
Cool bud - I'll do that.
Thanks, Bros.
Old Sep 17, 2009 | 12:31 PM
Maxpwer's Avatar
No turbo, no care!
Just call Nissan and tell them you need the upgraded "overbore radiator", grade 2. Personally I would just get the grade 3 overbore radiator for extra cooling since its the same price as grade 2.
Old Sep 17, 2009 | 02:48 PM
Turns out I did get slightly scammed - in the end he didn't even have the caustic. Before the owner got there I asked one of the employees and he said it's not caustic, they aren't 'allowed to use it' anymore. So I picked it up and paid him the $90.00, and he didn't even open the oil galleries - he didn't know how to, so it turns out the cleaning is probably a waste and didn't do much. The block looks very similar to how I gave it to him, except for the honing. The crank and bearing cap are the only things that didn't get cleaned in the tank, but those were cleaned in some booth type thing, and they look fully clean. He said there may be aluminum in the crank so he wouldn't put it in the hot tank. You should have seen how abrupt he was with the equipment, he even almost knocked down someones crankshaft right in front of me. There's like 100 blocks all lined up, and he was practically throwing my parts around right in front of me.
The owner is funny, although made mistakes, but at least he's a nice guy so I don't feel completely ripped off. He admits to me he's new to the engine stuff and only bought the plant 1 yr ago
Old Sep 17, 2009 | 02:52 PM
So Maxpwer, is there any way I can run the OEM standard radiator with those 0.5 overbore? I'd like to avoid buying it if I can get away with it, or will it overheat? The FSM doesn't mention replacing the radiator when replacing the pistons.
It turns out I'm going to have to re-bore. He slipped a 0.004" feeler gauge between the piston and the bore right in front of me, and it fit in. Out of curiosity i'm going to measure the honed bores to see how much he took off on the machine.
Old Sep 17, 2009 | 04:28 PM
Matt93SE's Avatar
STFU n00b!
nope. you need a Koyo racing radiator. the stock ones aren't up to the task.
Old Sep 17, 2009 | 05:39 PM
Hey buddy - is this the one you are talking about? The one at the bottom.
http://www.thepartsbin.com/catalog/?...294963637+9235
It doesn't mention racing though.
Old Sep 17, 2009 | 06:56 PM
Matt93SE's Avatar
STFU n00b!
no.. those are a stock replacement radiator. you need a better one than that.
Old Sep 17, 2009 | 07:54 PM
LvR's Avatar
LvR
I have done perhaps 10s of overbore replacement radiators and have always found that the single core version (as opposed to the more expensive double/triple core versions) always improves cooling because its got less wind resistance ..................
Old Sep 17, 2009 | 08:26 PM
i heard that the triple-core ones work just fine as long as you install an extra set of electric cooling fans on the front side end to help boost airflow even with the increased wind resistance (rewired to spin the opposite way of course... otherwise you're blowing air away from the radiator! )
Old Sep 17, 2009 | 10:55 PM
LVR I used all my measuring equipment, following exactly the service manual, and here are my clearance results (Post honing machine). Please look at the ones that failed and by how much, and let me know if I can ignore the machinists recommendation of re-bore:
PISTON-TO-BORE CLEARANCE "B" (CYLINDER BORE DIAMETER - PISTON SKIRT DIAMETER)
OEM Limit: 0.0006" to 0.0014"
Result:
#1 GRADE 3 0.0017" FAIL OVER LIMIT
#2 GRADE 2 0.0015" FAIL OVER LIMIT
#3 GRADE 2 0.0012" PASS UNDER LIMIT
#4 GRADE 2 0.0014" PASS @ LIMIT
#5 GRADE 2 0.0014" PASS @ LIMIT
#6 GRADE 2 0.0014" PASS @ LIMIT
Old Sep 17, 2009 | 11:02 PM
By the way Ben, I read your response right now above and it makes no sense. Have you even overhauled an engine yourself before?
Old Sep 18, 2009 | 01:06 AM
Maxpwer's Avatar
No turbo, no care!
Well if you can find them, the radiator out of the JDM turbo 3rd gen maxima, or the upgraded radiator that comes with the Nismo 3rd gen maxima turbo kit provides even better cooling! I had to call A TON of nissan dealerships but I finally found a Nismo turbo radiator and have never looked back!
Old Sep 18, 2009 | 03:44 AM
LvR's Avatar
LvR
Here's a novel idea:
Can somebody please explain to me what this limit is all about and what it means ito a rebore requirement?
Old Sep 18, 2009 | 09:35 PM
LvR's Avatar
LvR
1993-VG30E-GXE - Lets make it official then - I am now with Matt, and have to agree that you have absolutely no idea what you are doing.
You have absolutely no idea how to read a service manual - you also have no idea about the implication of the figures you see printed there.
That statement alone should have been enough to get this thread closed/locked and stuck up in the stickies as a perfect example of how not to go about sorting a 3rd gen motor.
You have lots of money you are going to be relieved of in this "rebuild process of the VG motor" and in the rebuild process you are undoubtedly going to also end up screwing up a perfectly good motor with close to pristine "ex-factory" tolerances by unnecessarily "re-boring" ................ and re-boring to a 2nd oversize on a std block with no significant wear (for F**k sakes!).
Its painfully obvious that not you, your original mechanic friend, his 15 year long engineering friend, your recent "friendly but ripping you off caustic friend" nor any of the other people you first mislead by supplying wrong FSM information and then interact with to illicit yet another (300th?) opinion that is completely useless on rebuilding this particular type of motor. Granted the VG's FSM doesn't go into the sorta detail the equivalent motor in the Pathfinder manual goes into (EM49 and EM50 goes into a bit more machinist detail) while confirming all the questions and concepts I have asked in this here thread, but any machinist that knows what he is doing will know the implications of those figures in the VG's FSM ............. thats why I suggested taking the motor away from the "friendly screwer" and giving it to a reputable machinist.
I have tried in this thread to make you see how absolutely ludicrous your mission is, but obviously failed miserably because you simply cannot do simple maths or comprehend what the figures in the FSM means - on top of that you plead ignorance, bliss and proudly proclaims the you are actually sorted irrespective of not understanding the question.
I simply don't have the time to teach you either thermodynamics 101, engine construction 101 or engine rebuilding 101 via the net on a open forum. Suffice it to say that with the time I had to devote to helping on this extremely complex topic, not a single logical argument has come forth from your side.
Very good example is this stupid idea about the replacement radiator required for a re-bored motor - WTabsoluteF! .................... and then on top of it when people starts taking the p*i*s*s out of the situation you don't know/understand that either - the fact of it all is that a 350cu" Chevy V8 can most likely be adequately cooled by the standard Maxima's radiator ................. and I found it quite hilarious that you asked Ben if he ever rebuilt a motor even though he obviously doesn't/didn't understand my questions about "in-spec" grade combinations and wear limits for re-bore requirements either.
............. and for those that will now have a cadenza about my response let me quote some of my exact words I have typed in private responses to questions on this topic over the last nearly 4 months:
No reflection on your abilities, but if I have to judge your experience on the questions you ask I am going to have to say stick with the oil-pump and sump and leave it at that for now.
I don't think you should necessarily plan on doing a complete major overhaul next summer either - especially if you are saying that the motor was fine. Fit the pump and sort the oil leaks and she should be fine for probably another 10 years
ANY grinding or resizing on journals on the crank instantly renders a std bearing un-usable because its the wrong size - soon as you start grinding on the crank, you need over-sized bearing liners to cater for the grinding actions.
IMO you simply cannot get ALL the spares upfront - you simply don't know if a regrind of any journal will be required (my guess not), or by how much it will have to be ground, so there is no way to figure the required bearing shell sizes or therefore part numbers to buy before the actual grinding work was completed.
As you have no doubt discovered, using the VG as a "first-time" complete overhaul project is a pain ito cost - spares are simply way too expensive to take a chance and experiment - if you were using a Chevy V8 it would be a totally different story.
Me? - I wouldn't even start to strip/overhaul the motor unless it somehow exhibits a major problem or irritation - if an irritation can be sorted cheaply I would do that, but imo a complete overhaul is totally out of the question - I would replace the motor with a Jap import.
Once again - I don't think I will do a complete overhaul on a VG motor due to cost - even on my own pristine motor - I would simply replace it if something serious goes wrong with it. As long as my motor is reliable and returns good comparative fuel economy, then it can be down a bit on power and its lifters can be noisy at startup, but I will simply live with it and treat the motor as "fragile" for as long as possible.
Old Sep 19, 2009 | 01:58 AM
Woahh - someones a little unstable.
I will take a look at your blob of info....but MAN OH MAN that's alot of info - but it looks to me like you took something personal, that I said to you - and I promise LVR I didn't mean to offend you in any way, and I don't mean to be a threat to you in any way either.
I shall get to this later, but I'll be using the Mitutoyo Dial Bore Gauge with 0.0001 resolution so I don't need to fiddle with those snap gauges anymore.
Old Sep 19, 2009 | 06:10 AM
Matt93SE's Avatar
STFU n00b!
Just because you have the good equipment doesn't mean you know what to do with it.
He's absolutely right in every aspect of his statements above
Old Sep 19, 2009 | 09:52 AM
CMax03's Avatar
LOL!!! Look the stock radiator can handle it...You're thinking to much into it dude.But there are some 2 core all aluminum rads available...
That .5mm/.020" overbore is the minimum get yourself some Oem.5mm oversized piston or someother aftermarket piston brand (Sealed Power).
Unless you've measured it for taper which involves measuring the cylinder /piston in three different location ( top of piston/cylinder, middle of piston/cylinder and bottom of piston(skirt)/cylinder) then at each of the three locations you'll measure your thrust dimensions and longitudal dimensions which are non thrust...
Personally you should have mic'd all your piston/cylinder dimensions b4 your send them off, so you would know what you had b4 you send them off. I told you in the hot tanking cont'd thread that i'd already disassembled pretty much everything for my machine all ready (lower cost) and we knew together that an overbore was needed due to an extensive gouge in the cylinder wall ( due to previous owner overheating the car)!
Get a good oversized piston and move on!
Old Sep 19, 2009 | 01:15 PM
Oh man - you dudes are hilarious. You need to get out into the real world a bit - this website is driving you cooky. Don't take this stuff personally - it's CAR REPAIR
