weird power loss
Old Sep 20, 2009 | 02:01 PM
gapboi210's Avatar
weird power loss
Max was driving great and I went to pass someone. I hit 85mph and was at about 4100 rpm all of a sudden when it started hesitating real bad. Doesn't feel like a single cylinder miss. Kept driving and it smoothed out. Then after it sat for about 30 min I drove it and it was missing like crazy for about a minute then cleared up with just an occasional hiccup. So far it seems that it gets bad after sitting then sorta clears up. What could of triggered this just from passing someone. I check MAF and FI connections and they didn't make any difference
Old Sep 20, 2009 | 02:38 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
cracked disty cap? loose plug wires? faulty TPS hard-idle switch?
Old Sep 20, 2009 | 05:59 PM
gapboi210's Avatar
just went out there and she started up and purred without any hiccups
Old Sep 20, 2009 | 06:29 PM
gapboi210's Avatar
can't think what would cause that miss just because of the engine being under a higher load
Old Sep 20, 2009 | 07:01 PM
did you check those items yet? my car kept hiccuping and it turned out to be a bad TPS hardswitch. reason being, it never gave me problems at idle (when the switch was supposed to have a closed circuit) but would give me problems any time i was off-idle.
Old Sep 20, 2009 | 07:10 PM
gapboi210's Avatar
Distributor cap looks ok. Problem when it happens does it both at idle and when driving.
Old Sep 20, 2009 | 07:13 PM
1992maximase30's Avatar
what about the rotor and the screw inside the rotor.
that seems to be a common issue with the vg.
Old Sep 20, 2009 | 07:25 PM
gapboi210's Avatar
whats the common issue? It coming loose?
Old Sep 21, 2009 | 03:48 PM
yea i think someone here had the tip of the screw break leaving the other half in the cam. so it would run like how your decribing or would start at all.
Old Sep 23, 2009 | 08:34 PM
gapboi210's Avatar
odd I went to go look at the cap and rotor. I noticed there was what looked like dirty water spots everywhere. Looks like the engine was getting wet everywhere. I checked and haven't lost any coolant.......odd
Old Sep 23, 2009 | 10:46 PM
ColombianMax's Avatar
I had the screw holding my rotor in place come loose and the car wouldn't start. This was like 2 years ago though..
Old Sep 23, 2009 | 10:48 PM
gapboi210's Avatar
cap and rotor was tight
Old Sep 23, 2009 | 11:00 PM
look at the connector ends of the spark plug wires. Do any of them look pinched in? if so you can use a flathead screwdriver to expand them out so they make good full conact with the disty, receptacles and the one to the coil as well.
Old Sep 23, 2009 | 11:41 PM
gapboi210's Avatar
connections all look good. Puzzled about the weird water spots caked with dirt all over..and hasn't missed since that day
Old Sep 24, 2009 | 06:26 PM
moisture...i assume.
Old Oct 2, 2009 | 06:24 AM
KaneStyles's Avatar
I got a problem with my maxima.... Rmps at idle is at 700 once i put it in drive it drops o 600 rmps... and when i press the window buttons to send down the 2 front windows the rmp's drop to 500 and engine feels like crap.... can someone help me with this problem? thank you
Old Oct 2, 2009 | 06:33 AM
try cleaning your iacv. if it's not able to properly adjust the airflow to compensate for extra loads (putting car in gear, turning the wheel, electrical loads, a/c) that would cause the RPM to drop the more stuff you use.
Old Oct 2, 2009 | 12:15 PM
Swampass's Avatar
I agree with the throttle position sensor idea. That SOB can wreak havoc on your idle, shifting issues for the transmission, and most likely a cause for erectile dysfunction.
It can be adjusted. A little turn can make a BIG difference. Turn, drive, turn, drive, etc. till if feels right.
Old Oct 3, 2009 | 07:28 PM
KaneStyles's Avatar
will most def take out my throttle body clean it up and see if its dirty it makes perfect sense. frist time running this engine sense it came from teh junk yard and drove 300 miles on it so far. and dont worry i change the oil, spark plugs, wires new disturbutor cap, and fuel filter. and thermostat too and all the belts. also did a proflush. added lucas heavy oil stabilzer. and drained it after 75 miles cause it didnt do any thing. then another oil change with engine restore AMAZING!!!. and now after 300 miles on it im gonna do a Dura Lube additive in the engine cause pops said so eh. lol cant question the old g's in mechaincs lol
Old Oct 4, 2009 | 01:17 PM
gapboi210's Avatar
i guess i should go ahead and try cleaning the intake and maybe seafoam it too while I am at it.
Old Oct 5, 2009 | 05:00 PM
KaneStyles's Avatar
where do you find seafoam to buy?
Old Oct 5, 2009 | 08:05 PM
gapboi210's Avatar
local autoparts have it, Autozone, Oreilly, PepBoys, Advance
Old Oct 7, 2009 | 02:55 PM
KaneStyles's Avatar
so i cleand the ivac and then the throttle body and advance the timing a little by turning the distubutor. the car when starts up cold idles at 1300rmps then goes down to 1000 rpms and once it warms up to 900rpms... i turned on the heat full blast the head lights and step on the brake and put it into drive and it idles at 500 and feels like its about to stall.... can somone help with this problem..
Old Oct 7, 2009 | 08:09 PM
DO NOT USE DURA LUBE!!! stick with the engine restore. leave it in there for the full 3000 miles. that stuff worked miracles when i had my honda and acura.
if you have the gxe model you can adjust the idle on the ecu and the iacv itself.
my maxima idle's at 400rpms...thats with out anything on. dont feel any vibrations, or does'nt feel like she's about to stall either.
Old Oct 21, 2009 | 08:14 PM
gapboi210's Avatar
hmmm started doing it again. Seems like it does it more in reverse. Maybe it's just more noticble.
Old Oct 23, 2009 | 04:40 PM
jona571's Avatar
I have a 93 max SE with 200,000 should I use the seafoam,,just looking for more power
Old Oct 23, 2009 | 11:57 PM
gapboi210's Avatar
don't thread jack
Old Nov 12, 2009 | 07:00 PM
KaneStyles's Avatar
How do i adjust the idle by using the ecu cause when its at 500 rmps it feels rough and feels like it going to break down. this is a big problem....
Old Nov 12, 2009 | 07:07 PM
gradually loosen the idle adjust screw on the iacv (underneath a black rubber cap... well assuming you have a VG) until your idle is satisfactory. there's a more complicated way to do it but try that first.
TallTom
57
Oct 14, 2025 05:16 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
