Problem with Foglights......
Old Nov 30, 2001 | 10:36 AM
seawolf14's Avatar
Bought a used 93 SE recently and it came with non-factory fog lamps. Unfortunately, they don't work. The fuse is good and and after testing the lamps themselves w/power on, I found they weren't getting any juice. Are there any other fuses for the foglamps other than the one in the fuse panel? How does one know if the foglamp relay is bad? Any other key places to check before I completely rip apart the wiring?
Old Nov 30, 2001 | 11:03 AM
«§»Craig B«§»'s Avatar
Re: Problem with Foglights......
there is just that one fuse
the relay is in the relay box just in front of the battery in the engine bay; they are labled on the cover for the box
just take out that relay and replace it with one of the others to test it
or you could put 12v and ground to pins 1 and 2 of the relay and you should hear a clicking and then check for continuity across pins 3 and 4
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
homewrecker
Sep 24, 2015 07:01 PM
