4th gen JL stealthbox?
Old Oct 11, 2009 | 06:03 PM
Dayle97SE's Avatar
can a JL stealthbox be wired for a 3rg gen with Bose? I have a 99 HU. I know the fit wouldnt be 100% in the trunk...just checking on wiring...
Old Oct 11, 2009 | 06:06 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
technically speaking can't anything be wired for anything? power in, sound out
Old Oct 11, 2009 | 06:14 PM
Spence's Avatar
It can be done. The problem with the stock HU's is that there's no rca ports. If you're having a pro install it, it'll cost you about 2-300, depending on where you go. But if you're looking to do it yourself, buy a line out converter($20 at any audio shop) and look up the proper wires in your HU online for your outputs, you can solder the LO converter's wires into that, then hook up your rca's to the LO and run them to your box. It's a pain in the *** and you lose some sound quality, but it beats going out and buying a new HU
Old Oct 11, 2009 | 07:50 PM
Matt93SE's Avatar
STFU n00b!
Supposedly the outputs on the BLose headunit are line-level outputs. I'd stick them on a multimeter and run some sine waves (go buy a test CD from an audio shop) through it to check the voltage output. long as you're under about 3-4volts at max volume on the wires coming out of the head unit, then you can wire them directly to some RCAs and run those wires to the amp.
If that doesn't work, then you will have to use a line output converter.
Honestly, you'll be better off scrapping the Bose and going with some decent aftermarket components/coaxes and a basic head unit. It's obviously more money, but I think you'll be happier in the long run.
Old Oct 11, 2009 | 07:51 PM
Matt93SE's Avatar
STFU n00b!
MAXSE5SPD
Sep 17, 2022 04:00 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
imported_Nismo_max
Sep 21, 2015 07:24 PM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
