VG Belts Before Engine Install
Old Oct 11, 2009 | 11:42 PM
1993-VG30E-GXE's Avatar
Can anyone remember if it's OK to install ALL the drive belts while the engine is on the stand, then plop the whole thing in.
I have the power steering pump removed with both hoses removed, so those too installed outside if possible?
(For some reason I don't know why, but I remember before engine removal, I removed all the belts while engine was in the bay.)
Old Oct 12, 2009 | 06:54 AM
kringle03's Avatar
Put your timing belt on and cover... but as for the rest of the belts... I believe you should prolly leave them off for install (alty and other components should be off the engine while installing anyway, so there's no point of having a loose belt hanging there) and put them on when you're done...
Old Oct 12, 2009 | 07:02 AM
CapedCadaver's Avatar
Call me Wookiee Goldberg
where is your a/c compressor? removed that too? Nothing wrong with installing belts ahead of time as long as the items to install the belts to are attached to their respective bracketry
i always unplug the wiring on the alty from the car (subharness 2 white connectors, and the regulator plug, etc), but i tend to remove the PS pump from the motor.... also i remove the a/c from the motor. and since you have to take the ps pump belt off, you might as well take the alternator belt off too.
Old Oct 12, 2009 | 07:11 AM
Matt93SE's Avatar
STFU n00b!
I'd say leave them off. it's a major beyotch to put the radiator/heater hoses on with the belts installed. leaving them off gives you more working room to get the belts on.
Old Oct 13, 2009 | 07:43 PM
Cool - i'll follow these tips.
Hondarydr
Dec 30, 2024 06:15 PM
tsi6001
Oct 3, 2022 10:23 PM
Ray229Harris
Sep 16, 2015 08:16 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
