Intermittent Problem for a Year now...
Old Oct 31, 2009 | 09:04 AM
94se5spd's Avatar
So, I have had this problem for a year now (or close to it). I have replaced the plugs twice now, most recently with a set of BKR6E-11 V-Powers (heat range colder than stock) new ignition module, new cam sensor, 2 different MAF's, new fuel filter. I always run premium (93 octane here) the timing is bumped a couple of degrees (it had this problem before I did that though). Since the new module and colder plugs it was better, but now it seems to be gettin back to it's old self. Under normal in town driving conditions it will "jump" as in like you floored it and let off suddenly and then lay over with no throttle response for a second or two then it will drive on just fine (maybe) the tach acts alittle wiered when this happens as well. When it's idleing the idle will drop like it's gonna die but it usually compensates and will stay running (occasionally it dies) It also has these symptoms under full throttle. Rarely i'll be cruising and the tach will drop from around 2200 to 0 and the car lays over. I've gotten to were now when this happens I'll push the clutch in and wait for the idiot lights to come on (engine light, oil pressure, etc.) and then resart it and keep goin. But, sometimes I have to turn the ignition off for a second and then try restarting it again. This is all intermittent. Somedays, it runs like I'm sure it did off the showfloor. Other's...I cuss at it all day. My fear is an itermittent problem with the ECU. Any help would be greatly appreciated.
Old Oct 31, 2009 | 01:54 PM
Garf's Avatar
when's the last time you cleaned the IACV and TB ? also sounds like it may be TPS related.
Old Oct 31, 2009 | 08:16 PM
94se5spd's Avatar
It's been about 7 or 8 months since the TB was cleaned, I havent pulled the IACV off to clean it. It dosent always do all of this though. Just sometimes. I've thought about the TPS but I thought it would do it all the time.
Old Oct 31, 2009 | 09:56 PM
Cravacor's Avatar
What do the plugs look like when you pull them? Maybe you are running too rich? Fuel injectors are staying open too long?
Old Oct 31, 2009 | 10:26 PM
Cliff Clavin's Avatar
Way out West
coil pack(s)
do a search for stalling or bucking
Old Nov 1, 2009 | 11:28 AM
Garf's Avatar
Originally Posted by Cliff Clavin
coil pack(s)
hebe94se5spd so i think 5 speed with VG engine so coil.
Old Nov 2, 2009 | 10:35 AM
94se5spd's Avatar
My car is a 92 VE 5 (I was lookin at a 94 VE 5 when I joined) When the coils crack on these cars can you always see them? Or are they so small they're hard to spot. I have had all 6 coils out of it several times, they all look fine, one of them tested about .2 ohms to high on resistance, it was on the backside of the motor. The plugs are a little dirty but they look pretty much normal.
Old Nov 3, 2009 | 08:12 PM
Way out West
My car had a bad rear coil pack and it did this. It looked brand new. I swapped almost everything imaginable because I thought the rears were all good. MrGone and I spend hours on this, just to find out it was my rear coil pack nearest the passenger side.
I bought a set of used ones from an .org member that wrecked his car and everything was fine after that.
Old Nov 8, 2009 | 11:43 AM
94se5spd's Avatar
Thanks guys
MAXSE5SPD
Sep 17, 2022 04:00 AM
Matt93SE
May 24, 2019 02:58 PM
intimidator
Sep 5, 2015 07:23 PM
homeyclaus
Sep 3, 2015 06:15 PM
yat70458
Aug 3, 2015 01:16 PM
