schematic electrical headlight hight adjustment
Old Nov 1, 2009 | 01:19 AM
jvc1986's Avatar
I can't find anythin in the 1994 FSM about the electrical height adjustment for headlights.
I pulled the headlights with this from a '89 and want to install it in my car, but need some kind of schematic to wire it.
Old Nov 1, 2009 | 07:33 AM
300zmax's Avatar
Originally Posted by jvc1986
I can't find anythin in the 1994 FSM about the electrical height adjustment for headlights..
electrical heigth adjust? never seen that.
they should be plug and play
Old Nov 1, 2009 | 08:02 AM
CMax03's Avatar
They should be the same unless someone modded those headlights!
Old Nov 1, 2009 | 11:22 AM
Garf's Avatar
pics are mos def needed. never heard of electrically adjustable headlights on our 3rd gens.
Old Nov 1, 2009 | 01:00 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
never heard of this before. the only electrical elements on the headlights should be the bulbs.. and MAYBE wipers (if some countries got headlight wipers) but otherwise i'm not aware of any other electronic elements in our headlights.
Old Nov 1, 2009 | 10:39 PM
jvc1986's Avatar
strange, did look original in the car, wiring to the motors was together with the other engine harness.
Pics:
Old Nov 2, 2009 | 03:52 AM
300zmax's Avatar
Pics:
http://i35.tinypic.com/20fospu.jpg
http://i38.tinypic.com/sbtwz5.jpg
looks like a definite mod. nicely done too.
Last edited by Matt93SE; Dec 20, 2009 at 08:04 PM. Reason: Please don't blindly quote a post with HUGE pics. it's rude and a waste of internet.
Old Nov 2, 2009 | 04:27 AM
jvc1986's Avatar
The switch looks like the one from the Primera, i'll check some of those FSM's.
Old Nov 2, 2009 | 05:24 AM
Kountz430's Avatar
bald aggression est 78
lets see what the front looks like, that'll definently be i nice mod and good find too i give it a 10 for rarity
Old Nov 2, 2009 | 06:11 AM
imo that looks like factory.. whether it came from a non-maxima car originally, or just some non-USDM 3rd gen, i can't say. But everything just looks pre-molded and pre-designed, rather than an afterthought. sadly without the control unit and some sort of sensor to measure level-ness, it won't work tho.
Old Nov 2, 2009 | 07:36 AM
jvc1986's Avatar
The front is just like my other lights, haven't mounted them yet, as I dont know what position they are in.
I'll do a test run to see if they work, in my FSM for Nissan Laurel, there is no control box for it's adjustable lights.
No sensor needed, the switch (right side of pic) controls height, for the Laurel that is.
Old Nov 2, 2009 | 07:48 AM
oh so the motor unit has the leveling sensor inside it? i guess that's convenient. in that case isn't it just a matter of tapping power and ground?
Old Nov 2, 2009 | 07:53 AM
Garf's Avatar
wow, i'm actually really surprised that no one (that has said anything in this thread yet) has seen lights like this before. this is pretty sweet. and imo they def. look factory. all the plastic moulding and screws etc line up perfectly and there are no hacking and cutting marks.
i wonder if courtesyparts or any dealer supplies headlights like this?
Old Nov 2, 2009 | 11:31 AM
jvc1986's Avatar
The height of the lights are adjusted with the 0-1-2-3 position switch (no sensor), when I set it at ie. 2 the motor goes to "step 2", so the switch has 12v in, and when switched to another setting it just send 12v to another wire.
Should be pretty easy to install I think.
Old Nov 2, 2009 | 11:42 AM
nalc's Avatar
yeah, that isn't auto-levelling. the **** makes the adjustments. Doesn't look aftermarket either, probably non USDM. Is that a city light it has too? Cool find.
Old Nov 2, 2009 | 11:48 AM
o... do you have the switch? where do you live anyhow? i'm guessing not in the US
Old Nov 2, 2009 | 12:02 PM
jvc1986's Avatar
Yes, you can see the switch in the second picture.
Live in Norway, so got headlight wipers too
European models both of them.
Old Nov 2, 2009 | 12:37 PM
nalc's Avatar
Bottom right corner.
Old Nov 2, 2009 | 12:54 PM
Originally Posted by nalc
yea i saw it after he mentioned it. it kinda blended in... that and huge pics are huge, even on my 1600*1200 screen.
Old Nov 2, 2009 | 01:03 PM
300zmax's Avatar
well looking at the picture that has the switch, if you look at the underside of the servo there are holes for what appears to be where the manual adjuster would screw on as well as an in print in the paint where it was.
either way im no expert on lights, i think wiking would know more about this set up if is stock maybe ?
non the less it looks cool.
Old Nov 2, 2009 | 01:09 PM
yea wiking might... wonder when he'll show up again...
Old Dec 20, 2009 | 07:53 PM
Garf's Avatar
...any updates on this? I'm curious.
tarun900
19
Dec 20, 2021 06:57 PM
Unclejunebug
Apr 2, 2016 05:42 AM
leatherneck
Sep 30, 2015 09:16 PM
