brake line?
Old Nov 30, 2009 | 12:58 PM
biggz2332's Avatar
brake line?
does anyone no the size the brake line on the VG model going to the brakes in the rear
Old Nov 30, 2009 | 02:43 PM
1993-VG30E-GXE's Avatar
REAR BRAKE PIPE (LH) 3/16" 25 FOOT Art No 884.BLT-3-25
REAR BRAKE PIPE (RH) 3/16" 25 FOOT
FUEL SEND PIPE 5/16" (DOUBLE WALL STEEL) - DOUBLE LAP FLARE ONLY 12 FOOT 884.BLT-5-25 17.50 per bag
FUEL RETURN PIPE 5/16" (DOUBLE WALL STEEL) - DOUBLE LAP FLARE ONLY 12 FOOT 25.00 per bag
FUEL TANK BREATHER PIPE ?" (DOUBLE WALL STEEL) - DOUBLE LAP FLARE ONLY
BRAKE LINE BENDER TOOL
SAE 45 FLARE TOOL
Old Nov 30, 2009 | 02:46 PM
Addendum:
The fuel pipe is actually just 5/16" Brake Pipe
The 25 foot length is only if you are going ALL the way from the rear calipers to the firewall intersection thing
BRAKE LINE NUTS:
#M5-3 (Standard Asian Nut) 10mm X 1.0 male no lead 16mm overall - SAE flare
Art No. 889.500 27.50
889.501
BLEED SCREW:
#BLM10 10mm X 1.0 steel bleed screw 33mm overall
Old Nov 30, 2009 | 03:28 PM
biggz2332's Avatar
SAE 45 FLARE TOOL
All i needed was brake line lol, so it's "3/16" I asked cuz I have found a max with a busted line, and I'm going to cut that busted line off and do a quick flare so I can purchase it and drive it home so I need to see what size lne I would needed thanks
Old Nov 30, 2009 | 03:59 PM
Matt93SE's Avatar
STFU n00b!
In that case, go to the local parts store and buy a section of 3/16" line with 3/8" fittings and unions on it and splice it using imperial lines... almost all parts stores have imperial fittings, whereas the 10mm x 1.0mm inverted flare fittings used on Nissans are pretty rare to find in a parts store. (both size fittings use the same size 3/16" tube)
Old Nov 30, 2009 | 04:12 PM
biggz2332's Avatar
Oh ok I got what your saying. Would I still have to flare the lines on the car itself?
Old Nov 30, 2009 | 04:47 PM
Garf's Avatar
screw it. just use duct tape
Old Nov 30, 2009 | 04:57 PM
biggz2332's Avatar
Old Nov 30, 2009 | 05:07 PM
Lapajgo's Avatar
Hope he is messing with you. Just brakes told me that it will cost me $500 bucks - hell no. The fitting is a miracle fix, I have two lines filed by my belts - and I patched them with fittings for some spare change.
Old Nov 30, 2009 | 05:08 PM
Barf was kidding.
Old Nov 30, 2009 | 05:11 PM
biggz2332's Avatar
Barf was kidding.
I know he was he doesnt want a member dead...
Thats alot of money for some line work
Old Nov 30, 2009 | 05:19 PM
Lapajgo's Avatar
In my case I have ABS(that is on the passenger side and the break lines hub is on the driver side) that means lifting the engine to replace the lines - they go around the engine.
Old Nov 30, 2009 | 05:22 PM
biggz2332's Avatar
oh your talking from abs str8 to the back. I'm just talking bout a lil section.
Old Dec 3, 2009 | 05:59 PM
internetautomar's Avatar
mod or sell?
I hope you aren't recommending compression unions be used on a brake line
Old Dec 4, 2009 | 02:21 AM
Lapajgo's Avatar
Yeah that's exactly what I used - 2 years NP.
Old Dec 4, 2009 | 02:46 AM
The brake and fuel line job is the WORST thing I've ever done. Bending those fuel lines around the firewall, is a major pain. It has to be bent so sharply or else it rubs on the steering rack boot. None of the OEM clamps would work, so I had to do makeshift and buy eye bolts. That and I broke that tension rod bracket bolt anchor when removing those gussets, so I had to weld to fix it. The union thing is a good idea, the lines seemed protected inside the gusset, so the corrosion didn't get to them all the way up the firewall, if I could re do it, I would have done all unions.
Old Dec 6, 2009 | 05:28 PM
mod or sell?
those are NOT to be used on brakes, they do not have the ability to withstand the pressures that a brake system can come under. Yes tons of people do it, but in case of a full panic stop that will be the point where the line comes apart.
Old Dec 6, 2009 | 08:16 PM
Matt93SE's Avatar
STFU n00b!
Hellz No. My local parts stores sell replacement sections of brake line with 3/8" or 10mm inverted flare fittings on them, and they also sell the fittings and unions separately- usually only in 3/8" for them though.
Old Dec 6, 2009 | 11:33 PM
How do they do it then in the garages, when they patch a short section of line - is there some special DOT approved fitting, but not called a union?
I noticed the old lines before I took mine out had a union in it for yrs, when they did a brake job a long time ago they must have patched it during a brake job.
Old Dec 7, 2009 | 07:46 AM
Matt93SE's Avatar
STFU n00b!
Read my post directly above yours.
Old Dec 9, 2009 | 01:04 PM
mod or sell?
jes checkin'
Depends on the shop. some will use the compression union because they don't give a F, some will run a new line front to rear, some will cut flare and use regular unions. for my brakes I would do "b" run a whole new line. a 25' roll of steel tubing is not that expensive.
Old Jan 25, 2011 | 01:15 PM
zhuk90's Avatar
how would you go about running new lines? would you just remove the origanal lines and follow that bath? or could you just cut corners? one of my brake lines busted(back right brake) right when i got the car.... i wasnt sure of what to do at the time so i replaced the brake line from where it starts with a skrew and have been rolling around for 2winters with three brakes.... i would like to replace all brake lines but following the stock lines seems imposibal!
Old Jan 25, 2011 | 07:15 PM
maximo018's Avatar
If your talking about the rubber hose to the caliper/ drum thats pretty easy. I'd go stainless steel braided lines. Wait... I already did. lol! If your on a budget crunch they have them on ebay for about $25-$50 a set. Other than that I'd go Goodridge.
Old Jan 27, 2011 | 12:55 PM
zhuk90's Avatar
no one of the brake lines right under the drivers side door busted.
Old Jan 27, 2011 | 08:51 PM
maximo018's Avatar
Oh! The hard line. you'll have to order that from Nissan or find a local specialist.
Old Jan 28, 2011 | 02:15 PM
zhuk90's Avatar
would the line come pre bent? that would seem really hard and odd to replace seeing that its bent in crazy ways...i would like to do the job by my self....
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
