misfiring/hesitation/bucking. UPDATE
#41
If I'm reading this right the reason was either one of the coil packs or you moved some other connector while swapping the packs. If you're still curious you could swap them back one at a time to see which one exactly. I know this contradicts d/c test you performed but that's life . If you swap them all in and car continues to run smooth then you can be sure the problem will come back. Next time around though you could start from coils and may be get to the root of the problem. Some of my car's electrical problems took a while to hunt down.
If you saw CEL and you cleared codes before chances are ECU stored new code(s) while it was lighting up CEL. If you read your codes again it might give you some clue. I'm not sure if 3rd gen ECU clears them automatically so I'd use this as opportunity to clear codes as well and make sure ECU doesn't have anything left.
#46
I haven't taken the car in for inspection yet. I want to make sure all my ducks are in a row before doing that. I have a few light bulbs to change and some other things that may not pass.
#47
I have had the same problem of misfiring / hesitation with a VE30DE, I replaced the fuel filter, fitted new Bosch fusion spark plugs, and wrapped insulation tape around all the tubes on the coil packs as 2 had cracked uppers, and one had light grey arcing spots on it's tube, and now it runs perfectly. I think these motors are very sensitive to spark plugs and coils. I intend to replace my coil packs with a sequential spark system which will be about a quarter the cost of new coil packs.
#48
http://forums.maxima.org/3rd-generat...-thoughts.html
Heres the a new thread so this one doesn't go off topic. Anyone got any ideas...?
#50
Does it feel like the car doesn't respond to your throttle activations? Thats how mine was and I suspect that the TPS was my problem although I changed alot more than that. Fuel filter, coil packs, o2 sensor, IACV, and MAF are also other areas to check out.
litch
123
01-04-2024 07:01 PM
mkaresh
03-12-2018 06:48 PM
KabirUTA13
19
10-17-2015 02:15 AM
