Anyone Install an Electric Oil Pressure Gauge?
Old Dec 25, 2009 | 09:42 PM
1993-VG30E-GXE's Avatar
Curious what the fitting is I need - is it a 1/4" or 1/8" NPT or is it some kind of metric fitting.
If I ditch the OEM idiot light by disconnecting it and snipping the wire, will the oil lamp be permanently ON.
Old Dec 26, 2009 | 01:43 AM
Hectic's Avatar
1/8"
The idiot light will be permanently OFF.
Old Jan 5, 2010 | 12:07 PM
GAMERA30's Avatar
From: Long Beach, CA is where i live. Queens NYC is always home.
wrong ... the guages come with 1/8" .. but u need a metric adapter to install. BEST way to hook it up is with one of those oil filter guage adapters from glowshift guages.com. The adapter we need is 5he same as an S13 240sx.
Old Jan 5, 2010 | 08:24 PM
Hectic's Avatar
Old Jan 6, 2010 | 06:51 PM
DanNY's Avatar
Ad·min·is·tra·tor
1/8 BSPT is the stock thread.
ONCE AGAIN THIS IS A SUGGESTION. ALL FACTS AND FIGURES SHOULD BE VERIFIED. AT NO POINT THIS INFORMATION SHOULD BE CONTESTED WITHOUT SOLID FACT AND FIGURES BACKED BY PHOTOGRAPHS. THE ABOVE INFORMATION WAS TAKEN FROM A FIRST HAND EXPERIENCE.
Old Jan 7, 2010 | 02:20 AM
Thanks everyone, i'll install this in the spring.
Nice picture by the way.
Old Jan 7, 2010 | 07:45 AM
Matt93SE's Avatar
STFU n00b!
Or you could just put a little bit of extra teflon tape on the 1/8 NPT and screw it right in like I did.
Old Jan 7, 2010 | 08:21 AM
cardana24's Avatar
Blown
^^That's the same thing I did
Old Jan 13, 2010 | 10:58 AM
Hectic's Avatar
PT (JIS tapered pipe thread) is identical to BSPT. These are Japanese cars, they don't use the British standard, they use the Japanese standard (PT as shown in the picture).
Old Jan 13, 2010 | 02:07 PM
DanNY's Avatar
Ad·min·is·tra·tor
i think we all agree there's two standard of measure in the world..right?
inch and metric.
inch (fraction) is generally only used in the US
metric is used probably in the rest of the world.
so you're telling me metric measure in Japan is different than metric measure in Europe?
are you REALLY having this conversation with me? it's METRIC...call it BSPT, JPT, PT, whatever...it's metric.
BTW...pls show me your oil gauge set up.
Old Jan 13, 2010 | 11:44 PM
Surprisingly I found a weird threading on the coolant drain plugs. Didn't fit any metric. Could be imperial on a jap block?
Old Jan 14, 2010 | 11:28 AM
Hectic's Avatar
inch and metric.
Well I said it was identical right? Seemed you were sarcastically implying I don't know what I'm talking about and that the diagram I posted was incorrect. I'm just sayin I know exactly what i'm talking about and the diagram is correct
Unfortunately I can't show off my oil gauge right now. You'll get your proof in due time, just be patient
Old Jan 14, 2010 | 11:30 AM
Chris Gregg's Avatar
Get Off My Lawn
I had to get the adaptor for installing my gauge. Originally tried the teflon and threading the 1/8 port into the block and it stripped. Luckily, threads on block were salvaged, but had to get the adaptor and gently thread it in to correct the damage and insure a tight/sealed fit. The adaptor is only a few dollars and worth it to not risk damaging the block and leaking oil. IMO.
Old Jan 15, 2010 | 09:55 PM
Good point chris. I'll copy.
Ruin the threads and your in a world of pain, you might need to .....oh god knows what.
Machine shop...Hand tap......don't want to think about it.
Old Jan 16, 2010 | 08:24 AM
Get Off My Lawn
I'll go ahead and send you in the right direction. At the top of the page I'm sending you there is an adaptor for the temperature which has been mentioned earlier in this thread. If you scroll down, you will find the adaptor for the oil pressure sensor. $11 is still very reasonable to me for making sure you've got a tight fit and NOT potentially damaging the block! This is where I got my adaptor....great guy to deal with, very prompt with shipping too!
http://www.z31parts.com/engineparts.html
Old Jan 16, 2010 | 10:36 AM
DanNY's Avatar
Ad·min·is·tra·tor
ummm the disclaimer is for 1993-VG30-GXE since he's always questioning everything i say.
your diagram is on point. but the stock hole is BSPT.
i don't care about your oil gauge...just the set up you have there similar to the diagram.
Old Jan 16, 2010 | 08:03 PM
Hectic's Avatar
Ah ok I thought you were making reference to the diagram or what I said..
I have the same tee and it will have the same configuration, retaining the stock idiot light switch, all that's installed ATM is the pressure sending unit which is metric threaded unlike most NPT aftermarket units, so it's screwed right into the block. Here's the tee and stock switch waiting to go on if you still need pics.
Cotozic
Jun 28, 2017 08:01 PM
homeyclaus
Sep 3, 2015 06:15 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
