91 Maxima VG Jumped time
Ok, I posted a few days ago about my car not starting. It seems that I have no compression in cylinder 5. Looks like the car jumped time. Now my question is what is the possibility that I bent the valves? Is the engine rebuildable? Thanks!!!
If it is only the valve you are concerned with, you may be able to fix only it. Naturally, it may seem worthwhile to take care of the other ones whilst the head removed, but you can rent the valve compressor from autozone to take care of one. In all it may cost less than $50 if you only took off the head whith the bent valve, you could even access it without removal of the head, but IMO you should take the head to a trusty machine shop who can check it for ANY issues (warpage, cam lobe damage from valve lifter, etc.).
I encountered some valve slapping after a bad timing belt replacement. I was certain I ruined the head and everything in it, but to my surprise, it was fine! The machinist, whom i trust with any project from this point forward, checked it over, mic'd everything, made sure the mating surfaces were flat, and checked each valve for roundness and straightness. He gave me a killer deal too..............
Needless to say, don't jump the gun, and inspect things thoroughly before looking for reman'd heads and new engines. Hope this helps..................
it is not a dual overhead cam engine.
Just fyi...
Ah ha, good eye sir. It never dawned up me, I will correct those typos, and do apologize to those whom I hopefully haven't confused! I do that regularly to myself enough, and the amount of laughter that ensues from it would keep anyone other than myself in a perpetual state of disarray. I do wish I had more pics to include in that timeline, could make the segments longer, and had everything in on the same day for that matter. The sun served as my shop light and labor timer........
Just pull the heads and replaced the damaged valves yourself and handlap them or have a machine shop perform the job/ or an entire head job or remove and replace with rebuild heads...you have plenty of options! Sorry to hear that happen disregard my last reply to your previous thread regarding the crank/cam sensor...I was hoping it wasn't your timing belt dude....
kjlouis
Nov 24, 2018 06:09 AM
Finkle
Sep 27, 2015 09:53 PM
laparka66
Aug 6, 2015 09:36 AM
