Windows rolling down
Old Feb 6, 2010 | 09:30 PM
Max_5gen's Avatar
Feel I'd share:
washed the car today and after pulling out of the wash (approx 2-3 minutes after the dryer) my 3 windows started to roll down on their own. It gave me a break as driver's side stayed up - it was -6 C outside. I'm ironed down 3rd gen owner so this kind of things don't upset me, just kind of ... unexpected. Luckily I was driving and not my better part - she'd freak out for sure . All kind of weird stuff started to happen: when I pushed rear left window switch on the driver's side door my left rear window goes up while rear right window goes down at the same time. The same switch down - they both go in opposite directions. Kind of makes sense, eh?
Old Feb 6, 2010 | 09:47 PM
chrome91's Avatar
that sucks, someone else posted about the window coming down by itself issue (1993-maxima-gxe or whatever his name is), should be on page 2 or 3
Old Feb 7, 2010 | 12:21 AM
maximo018's Avatar
Sounds like your master switch is getting ready to go. Gotta replace mine. All mine go down but won't come up at the master switch. I have to go around to each individual door and roll the windows up.
Old Feb 7, 2010 | 08:56 AM
maxitech's Avatar
Window master switches are one of those things I like to keep in the parts bin at all times (preferably more than one). I have replaced mine at least 3 times in 6 years. On the bright side, they are plentiful in parts yards and very easy to replace.
Old Feb 7, 2010 | 05:44 PM
Max_5gen's Avatar
It dried over night and started to work normally again. I'll look into this later when weather warms up.
Old Feb 10, 2010 | 01:25 PM
mszilves's Avatar
This particular problem is due to a resistor close to one of the caps on the master windows switch board, which if it has leaked, likely corroded the resistor connection to the board on one end. I had this same problem and resoldered the resistor and voila, windows go up again via the master switch. This is a surface mount resistor, very small, so requires a proper soldering iron and a steady hand. I'll try and get some pics later.
While you're in there, might as well replace the leaking caps and have the auto-down functionality back (and you can also mod it for auto-up also).
Or you could just replace the master window switch.
Old Feb 10, 2010 | 04:22 PM
Max_5gen's Avatar
Originally Posted by mszilves
...Or you could just replace the master window switch.
Where's fun in that? I'll take a look, thanks for the info.
Old Feb 21, 2010 | 06:46 AM
colinod's Avatar
The auto-up is relevant to my interests. Do you have a link or a write up?
Old Feb 21, 2010 | 07:40 AM
Phatmatt's Avatar
There was a write up on Craigs website, but the site no longer exists. I'm sure it is posted elsewhere, tried a search on the forum?
Edit: Here it is.
http://forums.maxima.org/3rd-generat...indow-how.html
Fbana41
Aug 29, 2016 12:18 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
