had a little accident...
Old Dec 6, 2001 | 04:29 PM
Maximan190's Avatar
tuesday (12/4) i was makin a U turn at an intersection and i had the green....from what i can remember there was a bus or some big rig in the left turn lane from the other side and my view was limited on the oncoming traffic......so i move out and i see a car rushing towards me and i misjudge and i hit the curb with my front right tire.....no significant visual damage except for a minor scrape on the rim and chip in the rubber on the tire. (see atchmnt) But now when i hold the steering wheel perfectly straight the car drifts to the right and sometimes ill get this knock noise when i make tight right turns. Could the algnment need to be re-adjusted or would it be something more major as, say, in the axle?
Old Dec 6, 2001 | 04:31 PM
Maximan190's Avatar
heh btw...car is a 92se....the car is still technically driveable but the only problem i notice thus far is that drifting to the right
Old Dec 7, 2001 | 11:20 AM
nupe500's Avatar
Jedi Knight
sounds like an axle...or bearings or something to that nature....I would say alignment, but it shouldn't make any noises...I don't think
O
Old Dec 7, 2001 | 03:07 PM
89Maxima's Avatar
If your makin a right turn and there is a noise then it might be your CV Joint.
Old Dec 7, 2001 | 03:35 PM
DanNY's Avatar
Ad·min·is·tra·tor
i wouldn't say it's axle. the axle is made to bend and turn.
you prob bent a suspension component.
check the following...strut, upper strut bearing, ball joint, tie rod, sway bar and endlink.
best thing to do is pull the wheel and see.
Old Dec 7, 2001 | 05:12 PM
Maximan190's Avatar
ok i took a better look and found out this....my front right wheel is pushed back....it scrapes against the wheel well when i make right turns
Old Dec 7, 2001 | 05:57 PM
DanNY's Avatar
Ad·min·is·tra·tor
time to visit the lower control arm..i would suspect it's bent.
Old Dec 10, 2001 | 11:19 AM
89Maxima's Avatar
Same here.
Garrettz459
Jul 6, 2013 07:50 PM
dr_rabias
May 8, 2011 11:05 AM
NJ3ndri
Jan 15, 2011 02:57 PM
T_Dwyer88
May 7, 2009 02:58 PM
