Cost of an entire new exhaust (state inspection).
Old Dec 7, 2001 | 01:06 AM
superdesi's Avatar
I had my car taken in for inspection Wednesday. Since I really maintain my 91 SE religiously, I thought I would be out of the shop real fast and cheap.
It turned out that my muffler had rust holes and the resonator pipe also had some holes. The mechanic also advised me to replace the front flex pipe. Basically, everything was replaced except the catalytic conv.
He charged me $550 plus tax. But now when I drive I can hear a hiss (like a snake) coming from the front only when the gas is depressed.
There is also a burnt smell that comes from the car after driving it around and parking it.
My question is $550 reasonable amount? And what could that burnt smell be?
Thanks.
Old Dec 7, 2001 | 01:07 AM
ToYLeT902's Avatar
JET Speed Lab
tranny? cat?
Old Dec 7, 2001 | 03:50 AM
nubiannupe's Avatar
OG Maxima.org Member
Roughly for that price, you could get a performance exhaust, so if that includes installation, then you probably are looking at a bargain. As for the smell, I'd speculate that if the parts are new, maybe it's some kind of coating or glazing on the exhaust that's burning off. But I'm just speculating and could be wrong.
Old Dec 7, 2001 | 04:01 AM
Dave S's Avatar
Re: Cost of an entire new exhaust (state inspection).
Thanks.
If you only hear the sound when accelerating, it's probably an exhaust leak. If it's not too bad, it may seal itself up once some rust & crud builds up in the connections of your new system. If it's real loud, I'd take it back and have the guy check it out.
Old Dec 7, 2001 | 05:24 AM
max95q's Avatar
I hear a hissing very faint when my car is at idle in park. I think it sounds pretty cool its really really faint but I hear it but only at idle in park. I also get a burnt smell after driving my car when I get out of it and it smells nasty but I looked under my car and something was leaking on my flex pipe and exhaust pipe. Could it be that the rear oil seal is gone and is leaking or maybe the oil filter isnt on too tight?? Its boggling me and irritating me because I dont want my car to catch on fire while rdriving and smelling some burning smell?? Do you all have any suggestions??
Old Dec 7, 2001 | 06:06 AM
DaBoxSE's Avatar
Hissing sound may be the exhaust manifold studs. I was actually in the same boat at you when I first got my car. Needed the front pipe and rear pipe & muffler. The total cost me under $400. I ordered the replacement parts and had my local mechanic put them on for me. All that was left eas the "hissing" of the exhaust manifold. I guess I got what I paid for because now, the rear pipe is rusted out and broke at the muffler. Now I need a new muffler and b pipe and it hasnt been two years... time to upgrade.
Old Dec 7, 2001 | 06:30 AM
mykizism's Avatar
Thanks.
for 550 dollars you could gotten a complete performace exhaust system.. even a new cat.. the hiss you hear is most likely a exhaust leak. and exhaust leak smells like a light burning smell.. almost like burning plastic. so the leak is before the cat converter. because after the exhaust pass's thru the cat then the exhause should smell kinda sweet and gasous.
so if it smells kinda burnt like plastic then its before the cat.. so your leak is probably before the cat.. anywhere near the manifolds or even on ur stock ypipe
Old Dec 7, 2001 | 07:57 AM
max95q's Avatar
ok never mined then if the hissing is in the frnt then it dosnt pertain to my car/ my hissing is from the back sounding like there is some pressure from the gas tank or maybe the pipe. its really nice to hear
Old Dec 7, 2001 | 10:59 AM
C-Dawg's Avatar
I'm just glad that I live in a state that doesn't require inspections. I've heard horror stories from all you folks!!!
Old Dec 7, 2001 | 12:08 PM
DaBoxSE's Avatar
I think its a fuel pump or something. I love it too
Old Dec 7, 2001 | 11:00 PM
flyry110's Avatar
burnt smell is normal for new exhaust. it will go away. also, depending on how he cut his pipe, will determine how long it'll smell. Redline quoted me 80 dollars to hang and bend 2 1/2 pipe from the cat back. then just buy a y pipe and a muffler and you're set. actually, he might do a Y pipe for me as well. Said about 140 bucks for that . . .
Old Dec 8, 2001 | 12:20 AM
superdesi's Avatar
Well this was the breakdown on the work he did:
1 Front Flex Pipe------$242
1 Resonator Pipe-------$89
1 Dual Tip Muffler-----$79
2 Chrome Tips----------$14
Labor to install this--$110
Total $534 (Gaskets/Clamps were free)
After I had the work done, I was itchy to find out what others were charging in my area. I called up and found these prices. $800(Firestone), $625(Meineke).
If the burnt smell is normal, what bout the hissing sound? I think I'll take the car back and ask him to check for leaks.
It just was a shock for me since I never paid that much for any repair since I owned the damn thing.
Thanks.
Old Dec 8, 2001 | 12:50 AM
Neice Anne
I wouldn't say the burning smell is normal... I didn't have a burning smell when I got a new muffler...
Old Dec 8, 2001 | 05:45 AM
flyry110's Avatar
muffler is in back, flex pipe is in front, if it doesn't go away then worry. . . . new exhaust has to break in.
Old Dec 8, 2001 | 09:54 AM
Dan 93 SE's Avatar
Exhaust
FYI,WSP non-mandrel y-pipe, with lined flex and dyno proven gains==$195
Our mandrel aluminized pipe is only $225. OE y-pipes are known power robbers because of their design. Ours are as quiet as stock, with a stock muffler and b-pipe.
Also, b-pipe shipment will be in in a day or so, we think they will be going fast as many are already sold, we have aluminized and 304SS.
WarpSpeedPerformance.com 1-866-801-9338
Dan WSP
Old Dec 8, 2001 | 11:17 PM
DaBoxSE's Avatar
Re: Exhaust
Dan WSP
Thank You!!
Old Dec 10, 2001 | 10:18 AM
DaBoxSE's Avatar
Re: Re: Exhaust
How much is a B-pipe? I need one desperately
Old Dec 13, 2001 | 06:47 AM
superdesi's Avatar
Update
I finally found the reason for the hissing.
I drove my mechanic crazy after he tried many fixes for my hissing problem. My entire exhaust system (less the cat) was replaced recently.
It turned out the only thing that solved the problem was NISSAN gaskets on the Y-pipe connections.
I hope that this will help future hissing issues on the exhaust.
Old Dec 3, 2002 | 06:27 PM
arges's Avatar
Have you considered that your valve covers/gasket might be leaking?
S.
Old Dec 3, 2002 | 09:50 PM
superdesi's Avatar
S.
I found the problem. The mechanics used the gasket that came with the new flex pipe. I took the car back and insisted that he install Nissan gasket, which solved it.
Mar 12, 2020 12:06 AM
knight_yyz
Oct 24, 2015 08:05 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
TheMafia
Sep 4, 2015 08:26 AM
