se cluster help
Old Mar 6, 2010 | 03:02 PM
Midnight Racer's Avatar
se cluster help
I just tried to install one in my gxe and ran into problem, the battery light is on, the rpm gauge doesn't work and the transmission is locked(unless I use the red button on the **** (automatic), I tried to reinstall my old one and its the same thing, I really need help as to what happened (headlights still work and so do turn signals)
Old Mar 6, 2010 | 04:37 PM
damn fuses, it was that but the se cluster the rpm gauge doesn't work but my gxe cluster does any idea why the se rpm gauge doesnt
Old Mar 6, 2010 | 06:14 PM
Phatmatt's Avatar
RPM gauge is bad on the SE cluster.
Old Mar 6, 2010 | 07:33 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
yea, must just be bad then. there's no difference in the electronics of one cluster vs the next as far as compatibility is concerned. the VE speedo has less degrees-per-mph just b/c it has to fit more MPH into the same sweep but it's fully compatible as well with the VG trannies' speed sensors.
Old Mar 6, 2010 | 11:06 PM
rpm gauge on the se is gone so luclily for me i can just swap out the white faces and put them onto my gxe cluster
Old Mar 7, 2010 | 08:59 AM
tv4184's Avatar
How do you swap out the faces? I'm guessing it requires the removal of the needles?
Old Mar 7, 2010 | 11:54 AM
maxinout93's Avatar
Are you swapping the 125mph for the 145mph cluster? Just wondering I wanted to see what it would be like to have the white in the day and the black in the night. Even though I like the green color of my GXE at night. Jus wanna try something different.
Old Mar 7, 2010 | 12:43 PM
Old Mar 7, 2010 | 11:02 PM
maxinout93's Avatar
Ohh wow That looks great I will grab one from the Junk yard this week.
Old Mar 7, 2010 | 11:18 PM
yea.. that's just a shadow cast by the overhang of the dash btw. i had one of the map lights by the mirror turned on, otherwise it was darkish outside. but that shows what it looks like in the day vs night (except that during the day the numbers will probably be totally black)
Old Mar 8, 2010 | 02:30 PM
maxinout93's Avatar
yah that looks great! Ive got to get one asap. while my car is down I may as well try and get most of the smaller things that are wrong with it done, as well as some upgrades.
Old Mar 8, 2010 | 08:25 PM
GRNMAXDMON's Avatar
no sir, all you have to do is just unscrew them from behind the cluster and they just come out as a whole assembly with the needles. all you have to do is just screw them back into your GXE cluster and your done. i did this to mine like 7-8 years ago.
Old Mar 8, 2010 | 08:27 PM
GRNMAXDMON's Avatar
yes it does because he swapped out the dull stock bulbs with L.E.D.'s
Old Mar 10, 2010 | 07:24 PM
bluewater's Avatar
Is there an instruction on how to remove the cluster from the dashboard? Do you need to remove the steering wheel?
Old Mar 10, 2010 | 08:18 PM
gfnk357's Avatar
I don't know if there are instructions up somewhere but I've done it before, it's not too hard to do and you definitely don't need to take the steering wheel out.
Old Mar 10, 2010 | 08:50 PM
steering wheel can stay. you have to remove the knee panel, the trim around the radio, the trim around the steering column, the trim that holds the cruise/mirror/defrost buttons, and the big black shroud around the cluster/vents/clock. about 20 screws' worth or so. then after all that's out, just tilt the wheel down, undo the 4 screws holding the cluster into the dash, and pinch the release buttons on both sides of each of the 3 harness plugs to release the cluster. I usually roll it toward me to get to those wires.
Old Mar 12, 2010 | 09:41 PM
looks exactly like mine, i oo did the blue led,s, will get some pics of mone
Old Mar 12, 2010 | 10:56 PM
maxinout93's Avatar
So its just a matter of unscrewing the bulbs and swapping them out with different color ones? Kool.
Old Mar 14, 2010 | 08:46 PM
GRNMAXDMON's Avatar
yes sir,
Old Mar 14, 2010 | 11:11 PM
maxinout93's Avatar
Great i just got an SE cluster out of the junk yard for my GXE. I swapped it out in like less than an hour, and it looks great, everything works fine, going to get those blue Led's from pep boys tomarro. Thanks for the idea.
Old Mar 15, 2010 | 02:55 AM
ColombianMax's Avatar
I had no idea pep boys sold leds, guess i'll have to go check them out
Old Mar 15, 2010 | 12:10 PM
maxinout93's Avatar
Yah they sell them in the car accessories section, they are like $20 for all four, and they have different colors too.
Old Mar 15, 2010 | 01:08 PM
damn thats expensive... I guess its the price you gotta pay if you dont want to wait a few days for superbrightleds.com leds in the mail...
$20 vs $11 ish ... eh not that much difference I guss but as long as they're similar style and quality
Old Mar 15, 2010 | 01:26 PM
my cluster
Old Mar 15, 2010 | 06:22 PM
maxinout93's Avatar
my cluster
that looks great, where can you buy them from for 11 bucks? PLease let me know. Id rather spend $11 vs $20 and wait for them in the mail.
Old Mar 15, 2010 | 07:11 PM
Phatmatt's Avatar
superbrightleds.com
Old Mar 15, 2010 | 07:36 PM
maxinout93's Avatar
Originally Posted by Phatmatt
superbrightleds.com
I lookd on there but I dont know what size our instrument cluster bulbs are. I know the bulb type, but the site is saying the bulbs come in 3mm 4mm n 6mm? Would it affect the operation of the turn signals?
Old Mar 23, 2010 | 11:03 AM
maxinout93's Avatar
Is there a specific type of bulb I need to get to order the L.E.D's from superbrightleds.com?
jsmith24
Feb 1, 2016 12:35 AM
Max139617
Sep 6, 2015 06:02 PM
