Temp gauge...
Old Dec 7, 2001 | 11:09 PM
DaBoxSE's Avatar
Temp gauge...
I drove a total of 100 miles today and tonight on my way home I glanced at my temp gauge and saw that it was about 1/4 above C. Then about a minute later it looked as if it was going lower. I was driving about 55-60 and finally the needle went below C! I thought this was odd b/c I was driving the car around for 2 hours straight. It kept going above and below C until I got home. What does this mean? The needle is almost ALWAYS just under half way. Any Ideas?
by the way, it was about 40*F tonight when I noticed it.
Old Dec 7, 2001 | 11:18 PM
flyry110's Avatar
sounds like you need a thermostat. not too hard to do yourself adn pretty cheap. good time to flush coolant while you're at it. . .
Old Dec 7, 2001 | 11:29 PM
Aaron92SE's Avatar
NWP Engineering.com
When it's cold outside and I am running my heater full blast. I've noticed that my temp needle will sometimes get a 1/4 above the C. But, it won't stay there. It usually stays just below halfway. But, if your needle gets as low as yours, there's something wrong.
Old Dec 10, 2001 | 12:09 PM
DaBoxSE's Avatar
Okay, I think this may be the problem. So how much is a new thermostat? and how hard is it to replace? I havent done this to my car yet. Thanks.
Old Dec 10, 2001 | 12:24 PM
DaBoxSE's Avatar
Old Dec 10, 2001 | 12:35 PM
crsmax's Avatar
Its either the thermostat or a sensor for the temp gauge. It may even
be that the needle in the gague pod may even be off... More than likely it is one of the first two...
Old Dec 10, 2001 | 01:22 PM
DaBoxSE's Avatar
I have also noticed that at times my heat isnt as flaming hot as it used to be. It take way longer to warm up than it used to. Does this have anything to do with it?
Old Dec 10, 2001 | 04:39 PM
D-DOT's Avatar
Where is the thrmostat located?
Old Dec 13, 2001 | 01:25 PM
DaBoxSE's Avatar
Bump
Old Dec 13, 2001 | 01:59 PM
Brandon90gxe's Avatar
hmm..not sure where the thermostat is located, but my temp guage did somethin intersting.. my car had been running, and then i did some traying with my car and after i parked my car for like a minute turned it off.. when i turned it back on the temp guage was stuck at the bottem for like a minute or two before it floated back up to the middle position.
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
fastcarny
Oct 6, 2015 10:42 AM
msellas
Sep 23, 2015 09:16 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
