Rewiring For Clear Corners
Re: Rewiring For Clear Corners
Originally posted by Coolice19
Hey I saw something on here about people rewiring there corner lights after they get clear corners. What does this do and how do you do it? thnks for any help.
I think it makes it so your corners stay bright like they are when you put on your turn signal.. instead of being dim until you turn on the signal. Here is craig's website with the how thttp://www.prism.gatech.edu/~gte671n/mymax.htmlo on the mod:
Originally posted by ngthing
check my website. it's easy. you don't even need to rewire.
proper way to rewire is to physically rewire it using the proper methods.
Originally posted by flyry110
there is a single fillament bulb that fits. the same one that's in your front turn signal. it's bright all the time. but you don't have your turn light. no mods at all required. just buy the bulb and put it in.
1157 double filament (double contact on the base)
the corner lense is 1157
the bumper lense is 1156
how can u run a 1156 in the corner lense when it's made for a 1157?
the tabs are offset in a 1157 (so u don't run it the wrong way)
the tabs are same distance on the bulb on 1156 (doesn't matter which way it goes.
now what's this bulb that u speak of?? please enlighten me
Originally posted by DanNY
if you don't have to physically rewire anything then i would assume you're prob sanding off one **** of the bulb and jamming it in there. will it work? sure..is it safe? no.
dan, i've had no problems so far with just putting in the bulb backwards. i did not need to sand the **** off the bulb.
ok well that's not the "right" way to do it..but it's your car. do what you want.
Thnks for the help guys seems like its pretty easy to do so im gonna try it when my clears come in.
yeah but when you make em bright all the time, don't you lose your turn signal light? you know, the one that goes on on the side.
Originally posted by noleafclover
you don't have to wait for your clears. it does the exact same thing with the marker being orange or yellow or whatever...
when you turn your signal on with the rewire, it doesn't get any brighter, but it is already as bright as it normally is with the signal on.
You wouldn't lose your turn signal either.. the brightness with the turn signal is just one of the things that lets people know you're turning.. there are also turn signals independent of the corners..
Related Question…
Guys,
I've installed my clear corners and I like the way they look (even though they're newer than the headlamps, they look much better on my car than the stock ones did). Anyway, as I was doing the install, I accidentaly pulled out the wires for the turning signal bulb on the driver's side. I decided to go with white bulbs instead of the yellow ones, but my driver's side blinker doesn't work. Any suggestions?
peace2u
peace2u
Apr 16, 2020 05:15 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
