How to operate the keypad on your doors
i never had the car manual to my car.
I do know how to punch in my security code
and i know how to lock the doors pressing the "90" key but what do/how to
use the TRK and WDW buttons?
RED BLUE BLUE ORG
C TRK WDW LCK
ST 12 34 56 78 90
RED BLUE BLUE ORG
C TRK WDW LCK
ST 12 34 56 78 90
for the trunk and windows, lets say your code is STRT 5 9 1 3. so, go STRT 5 9 1 3 and then hit the button with TRK on it, and your trunk should pop open. for the window, hit STRT 5 9 1 3 and then hold the button down with WDW and your windows will roll down
I don't know if this will be useful to you cause it seems you know your keypad
entry code but maybe somebody might need this info cause I know I sure
did at one point. The location of the 7 digit access code 4 the keypad is on
the control unit for the keypads. I took my glove compartment out to access
the control unit and the code is part of a sequence of serial like numbers. I'm
not original owner and previous owner had no clue and only the valet key
which I found out later(****in' crackhead). Anyway My 3rd gen Max is a 89'
and in excellent shape for a 20 year old car and I just hit 150 thousand on
original engine and tranny. She also has the Sonar II Suspension which is
a dope option and rides nice, I'm gonna replace the front/back struts soon
just to tighten up the ride alittle bit and add front/back strut tower braces.
Anyway I hope that info might help you or somebody, Shiloh.
oh no thanks alot this was a question that i have been meaning to ask for over a year but it kept slipping my mind because i had other major headaches with the car. I finally know how to use all the functions on the keypad now.
i use to unlock the car then open the door to press the trunk button to open the trunk, now i know how to do it from the keypad.....
AND as soon as i replace my drivers side master switch and replace the window regulators in 3 of my windows i'll be using the window option too!!
i just figured this out today, only my drivers window goes down, but my passenger one doesn't go down anyway, so i guess it's just the front windows that go down,
i also heard that the sunroof opens, i don't have a sunroof so i wouldn't know for sure
Yep, only the front windows and the sunroof if fitted.
REDinLV
Aug 15, 2024 12:30 AM
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
