Help with fornt passanger wheel bearing replace??
Hey guys i have a 92 nissan maxima se dohc and am trying to replace my front passanger wheel bearing. I removed the tire brakes and the caplier but dont know how to access the wheel bearing itself. What do I do next?? Anybody have an online manual for it??
It's easy... take off: ball-joint, strut, outer tie-rod, axle nut, abs sensor. After all this is removed pull the steering knuckle off of the axle. Take care not to pull the CV Axle out of the transmission housing. If you do pull it out by accident don't panic, a lot of ATF will spill but you can pop the axle back in and add fluid. Once the knuckle is removed you can take it somewhere to have the old bearing pressed out and the new one pressed in.
-You're going to need an alignment after all this/
look it up on you tube, so many tutorials.
That is how I learned my stuff.
http://www.nicoclub.com/FSM/maxima/1994/
here is link to FSM
here is link to FSM
boomerbrian
Nov 8, 2015 05:10 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
