speedometer cable location
Old Dec 10, 2001 | 05:42 PM
barrsw51's Avatar
i have a broken speedometer and cannot locate where it is 1992 maxima automatic. anyone know?confused
Old Dec 10, 2001 | 05:54 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
heres my shot at it-->
speed sensor location---->
open the hood, stand on the driver side of your car, look down at the tranny, you should see two cables with grey "snap-on" harnesses midway on the cables, (if I remember correctly) the harness on the right is the speed sensor, follow it down to the tranny and the speed sensor should be right there....thats as good as I can decribe it!
Old Dec 10, 2001 | 06:15 PM
MadMaxBrent's Avatar
They don't have a cable. The Maxima utilises an electical signal from the sensor as described by DA-MAX.
Brent.
Old Dec 11, 2001 | 04:18 PM
barrsw51's Avatar
Brent.
Thanks'I found it I bought a book that shows a cable. 1985-1992 haynes repair manual.
Old Dec 11, 2001 | 09:28 PM
PDubs's Avatar
Perhaps 93-94 Maximas have the electronic version?
Old Dec 12, 2001 | 10:55 AM
Manual vs Auto ?
Old Dec 13, 2001 | 11:31 AM
Pit5Bull's Avatar
Related Question…
I have a 5sp 89SE, and I've noticed that my spedometer will occasionally drop to zero when driving on the freeway or on the street. Do I have to have a new speed sensor installed, or is there some other problem that I have to worry about. I just recently had my tranny rebuilt, but this problem was happening before I had that work done. Any suggestions would be appreciated (I think I asked this question once before, but don't recall getting a definitive answer as to what to do.)
peace2u
Old Dec 13, 2001 | 11:44 AM
Re: Related Question…
peace2u
It is most likely your speedo unit. If when your speedo drops to zero, but your odometer still ticks over, you can rule out your sensor. Seems to be quite common.
Brent.
Old Dec 13, 2001 | 02:25 PM
Pit5Bull's Avatar
MadMaxBrent…
The odometer stops turning too when this happens…
…what could this be???
peace2u
Old Dec 13, 2001 | 02:41 PM
Re: MadMaxBrent…
peace2u
Hmm, still sounds like the speedo unit.In my case it was sometimes just the speedo and sometimes the odo and speedo. How frequently does it occur? If it occurs really often, like at least once a day, you could purchase a new sensor, install it and if the problem goes away then you have a solution. If it still occurs with the new sensor then you can rule out the sensor and take it out, clean it up and return it for a refund (check with your parts store about refunds). I did this first to confirm that it wasn't the sensor. Got a second hand speedo unit and I have had no problems (touch wood) for the last 6 months.
The way these cars works is that the signal is processed by a micro at the speedo unit which then drives the odo, speedo and I assume a signal for the ECU. So it is hard to track down faults. Sometimes it is a fault solder joint, bad micro, bad speed sensor and so on.
Good luck!
Brent.
Old Dec 13, 2001 | 02:48 PM
Pit5Bull's Avatar
Re: Re: MadMaxBrent…
Thanks MadMaxBrent!
I'll look into this solution and let you know how it goes. The problem occurs about 2-3x/week, so it's not an everyday thing, but it is pretty annoying - plus it makes me weary as to how many miles my car REALLY has on it. Thanks again, bro!
peace2u
my03maxima
Jul 28, 2024 07:40 AM
gigabyte
Jan 6, 2017 06:05 PM
RealityCheck
Oct 2, 2015 06:34 PM
fx4five
Oct 1, 2015 04:58 AM
