HELP!! Engine shakes violently at 1500rpm only?
Old May 12, 2010 | 07:39 PM
wcpierson's Avatar
My engine shakes pretty bad at 1500rpm with a partially open throttle and only at 1500 rpm. Everything else including WOT is smooth sailing. I dont get it. Any idea?
Old May 12, 2010 | 07:40 PM
Gunther's Avatar
How bout idle? I bet its an injector.
Old May 12, 2010 | 07:50 PM
wcpierson's Avatar
Idle is pretty smooth...not perfect but not even close to what 1500 rpm is like. Ill check the ohms on the injectors this weekend. If its an injector or 2 why would it only be at 1500 rpm?
Old May 12, 2010 | 07:55 PM
Gunther's Avatar
My experience with downed injectors has been a lot like what you describe. I think at higher RPM's and with more throttle (WOT) the engine just gets enough air to more or less make up for the stuck open injector. Another simple thing would be to check to see if your exhaust smells like gas.
Old May 13, 2010 | 10:36 AM
Darkwing48's Avatar
Does this towel smells like Chloroform?
Old May 17, 2010 | 09:18 AM
alltrac88's Avatar
it sounds like a vaccuum problem to me, maybe a leak or iacv?
JoshG
51
Sep 21, 2015 10:41 PM
jchronis2552
Sep 21, 2015 05:52 AM
Socalstillen
Sep 20, 2015 11:46 PM
Bonka
Sep 14, 2015 11:18 PM
