Right Hand Low Beam Problem
Old May 16, 2010 | 05:24 PM
Maximus94's Avatar
My passenger side low beam won't come on. I thought it was the switch, but after I replaced it, the problem persisted. I am able to manually connect the pins of the switch to make the driver side low beam come on, as well as both high beams. But when I connect the pins that should turn on the right beam, nothing happens... Any thoughts?
I realize that there is an old thread, but that one is mainly about the switch.
Old May 16, 2010 | 05:30 PM
richard_85zxt's Avatar
the switch is the most common but sometimes there's a short in the wiring harness leading to the switch, try moving the switch around while plugged in but not attached to the column and see if it changes, if it does, time to find your short.
Old May 16, 2010 | 05:59 PM
Maximus94's Avatar
Do you mean jiggle it around and see if that works? I've actually eliminated the switch from the picture and have been playing with the contacts on the harness.
Old May 19, 2010 | 08:47 PM
Jameez's Avatar
Check the bulbs socket, I had mine start to melt due to corrosion. They sell new sockets at the auto parts stores. Solder and shrink tube the new socket in and you should be in business. If thats the problem!!, Which it sounds like to me.
Old May 31, 2010 | 07:58 PM
Maximus94's Avatar
Well, now I feel stupid... It happened to be the low-beam filament Thanks for the help anyway.
Old May 31, 2010 | 08:46 PM
Hatmanafro's Avatar
woooooow.. hahahahah. its all good man. happens to everybody.
DJLAX152
May 4, 2021 11:46 AM
Maxima.KsA
May 15, 2020 04:14 PM
Mar 12, 2020 12:06 AM
markevans999
Sep 10, 2015 04:29 PM
TheMafia
Sep 4, 2015 08:26 AM
