Electrical Grease on injector plugs?
I have been chasing a misfire and think it may be the injector plugs. They are all cracked and brittlle. Moving them can make anywhere from a minor change in idle to a dead miss. I ordered 6 new ones. I was thinking about putting electrical grease to help seal them and prevent corrosion. How ever I was concerned that the electrical current could cross between the pins through the grease and short.
Is this a valid concern?
I think I am going to hit the injector pins with a dremel briefly to get that green corrosion crud off of them.
nope; dielectric grease is non-conductive.
how it works: the contacts will move the grease out of the way of each other, causing the current to flow. it fills the extra space, covering the rest of the connection, preventing the corrosion commonly found in these type connectors.
(you probably know this, but it's for others)
I got them off ebay, Im sure you could splice them in with connectors, but I am going to solder them for a corrosion resistant connection. (never soldered before and have been practicing on scrap wire lol.)
http://cgi.ebay.com/ebaymotors/EV1-N...Q5fAccessories
jmlee44
10-02-2022 02:13 PM
Unclejunebug
04-02-2016 05:42 AM
