interior lighting question
I plan on installing a set of 4 of the same door courtesy lights around the floor areas for extra convenience. I want them to only illuminate when the doors are open (this part I can figure out) but I want them to illuminate and dim out like the dome light does (this part I can't figure out).
I also don't want to just tap into and draw from the dome's power source, so I know a relay will come into play here. Advice? What's the right way to do this w/o any overloads on the fuses? Thx
as a reminder, relays are on/off, not high-low/off; a relay won't help any, probably won't be any use at all.
in order to dim, you will need some source of dimming, whether it's the dome light power, or another auto-dimming circuit.
Great, I was afraid of that. So what's the safest way to tap into that dimming circuit?
I thought about that, but are those wires strong enough to support that kind of current? We're talking 4 extra incandescent bulbs... Anyone else's opinion on this strategy of using the dome power and increasing the fuse load?
if it handle the load, you will need an alternate option.
Engineer's approach, there one way to find out: blue smoke or no blue smoke, at least you learn something.
By the way hooking a device in parallel is a current divider. You might want to duplicate the circuit at its power source.
Wire a decent sized capacitor to one courtesy light in parallel with the bulb or LED, when your door switch (ground trigger) is shut off, the cap will act as a dying battery creating a dimming effect on all 4 courtesy lights.
I made a video to demonstrate. Use a heftier capacitor. I used a small 25v 100uf for this single LED and it dims pretty quickly. Do some trial and error.
doobadoo
Aug 15, 2015 06:43 PM
