Radiator Fans
Radiator Fans
Does anyone know which of the two fans moves more air? There is one fan with 4 larger, equally spaced blades and the other with 5 smaller unevenly spaced blades. Because of the turbo in the way, I can only run one fan but I would like to use the one that moves the most air.
No one knows the differences between the two fans?? The one on the drivers side is the "main fan" by which I mean it comes on based on engine temp, and the passenger side comes on when the A/C is turned on right? Would it stand to reason the "main fan" moves the most air?
Either based on the number/spacing of the fan blades or the location/function of the fan, what would be your best guess as to which is the more powerful?
time to call mythbusters! I know this may not be the right way but what if you set each fan on individually outside the car and you move as far back as you can feel the wind and which ever one has the breeze reach you furthest determines which provides more air
this almost seems plausible... the more air it pushes, the more air resistance it should have.. and the more air resistance it has the more current it should draw.
, yah can't maneuver the turbo/tubing/piping/intake tubing around enough to make both work? Any pics of under the hood of this turbo Max, would help with suggestions.
Me? - I would approach this from the other side - literally.
Rip out the air-con radiator.
Get a "pushing" type of aftermarket cooling fan and slap that on the front of the radiator where you removed the one original fan you don't have space for. With a turbo setup I would think that cooling is bound to be rather critical, and while the std 3rd gen cooling system is man enough for the average worst case user, adding about 40% extra heat while removing a fan and also effectively blocking part of the radiator is bound to result in misery.
But both fans come on at the same time...kind of. When the ECU kicks on the fans, the driver side fan won't move until I move it. I guess the motor is starting to go out.
Me? - I would approach this from the other side - literally.Rip out the air-con radiator.
I'm going to retract this statement. Earlier I checked the fans and they are different. The 5-blade fand I have it on the passenger side and the 4-blade on the driver side. When they come on, I can feel the 5-blade fan blowing more air than the 4-blade fan.
Thanks guys for time and thoughts, keep em coming!
Unclejunebug
Apr 2, 2016 05:42 AM
RWCreative
Sep 21, 2015 11:01 AM
