Spacers sizing
Old Jun 21, 2010 | 09:44 PM
Jcarryl's Avatar
Spacers sizing
What would be a recommended size for spacers on my max ? ive got a set of maxim ahead wheels 17x7's 42 offset. I just wanna pull the front and the rear out a lil to make it a lil more flush. I wont the rear to be out a lil more than the front but i just wanted to get some input and recommendations.
Old Jun 22, 2010 | 01:05 PM
Hatmanafro's Avatar
thats helllla offset. lol
couldnt u mount the rims and then meausure how much u would have to go till its flush?
Old Jun 22, 2010 | 02:48 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
15mm will be good. i had some with 22mm offset (equivalent of what you have w/ 20mm spacers) and it rubbed the rear fender. so 15 would be perfect.
this is what my 17x7+22mm setup looked like w/ 225/50/17 tires
Old Jun 23, 2010 | 09:50 PM
Jcarryl's Avatar
Yeah i suppose i could have done that lol i got kinda lazy tho
Old Jun 23, 2010 | 09:53 PM
Jcarryl's Avatar
Thank you sir
Old Jun 24, 2010 | 08:51 AM
James92SE's Avatar
2 VE's are better than one!
This is exactly what you need to do
Jcarryl... just stack washers on your wheel studs to bring the wheel out a bit to where you want it. When it's out where you want it, measure the thickness of the washers and there you have it.. that's the size spacer you need. If you need to go much more than 15mm you'll probably need the adapter-type spacers.
My spacers are 22mm so they're the adapter-style
Old Jun 24, 2010 | 09:28 AM
GRNMAXDMON's Avatar
don't you need to get longer wheel studs when you put spacers on there? where can i get some longer wheel studs?
Old Jun 28, 2010 | 07:13 PM
James92SE's Avatar
Yeah, I think you need longer studs if you go longer than 10mm or so (or it might even be less)
The adapter-style spacers don't require longer studs
Old Jun 29, 2010 | 12:20 AM
maximo018's Avatar
I got 60mm carbon Nismo studs for my 5th gen in the rear with 15mm spacers from Courtesy.
Old Jun 29, 2010 | 09:09 AM
shiloh51933's Avatar
I would go adapter style spacers like suggested here by our fellow forum member. Rigg ups are dangerous and can ffff up your axles!!!
Old Jun 29, 2010 | 09:56 AM
Matt93SE's Avatar
STFU n00b!
1/4" is as far as you can safely space your wheels out on stock studs. any more than that and you need longer wheel studs. the NISMO studs aren't cheap, but they're the cheapest quality option for you. or you can pay a buck or two more for some ARP wheels studs. you're looking at over $100 for the set of 20 though.
as for how far to space those wheels out, with a 17x7 +42, you can get away with a 20mm spacer as long as you don't go wider than a 225 tire. if you go to a 235 or 245, you'll need to roll the rear fenders.
Old Jun 29, 2010 | 10:58 PM
Jcarryl's Avatar
Thanks everyone for the input! Man i love this site, my maxima is my pride, joy and never ending project. Its soo good to to talk to ppl who feel the same lol
Old Jun 30, 2010 | 08:50 AM
eh.. on a native 22mm offset (identical to 42mm-20mm) with a 225mm tire my rears rubbed badly on turns even with brand-new poly link bushings. they still have the gouge-marks to prove it. struts were blown on stock SE springs, but still, the minimum wheel gap in the rear was no more than what the average dropped car would see.
Old Jun 30, 2010 | 11:26 PM
bigmax90's Avatar
Its the love for our "maxine"
Old Jul 1, 2010 | 06:37 AM
Matt93SE's Avatar
STFU n00b!
the blown struts were likely a factor in that. I'm lowered more than most here and don't have problems w/ 245s on +22 offset. (My only rubbing issues are in the fender well where the rears rub against the top of the wheel well.)
Old Jul 1, 2010 | 08:40 AM
Cliff Clavin's Avatar
Way out West
I had 17x7 +42s and they looked a lot better with just some 5mm spacers on the rear. It made a big difference in how it looked and I didn't need longer studs.
Here is a photo of the rear with those wheels on (I have since sold the wheels):
Old Jul 1, 2010 | 09:33 AM
interesting. perhaps if i'd had a stiff rear swaybar it wouldn't have sunk down enough to rub even with blown struts, tho of course having good struts are more important than a swaybar. was that on 8" wide wheels that you had the 245's? not that it matters, 245 on any width of wheel will be in the same position if the offset stays the same.. just stretched or scrunched depending on the wheel.
Old Jul 7, 2010 | 10:05 AM
traxtar944's Avatar
Would be lost w/out the org
If you decide to get spacers send an email to wheeladapters@aol.com (email Mack or Jenny). Tell them the year, model, make, front or rear, and they take care of the rest. I just got 6mm hubcentric & studcentric spacers from them for $40 shipped to my door. They are turned aluminum, and have a very nice fitment. I actually had to drill the stud holes a bit because they were so tight that it was very difficult to remove them.
This is not the same company as wheeladapter.com (Fred Goeske), which has very high quality parts as well but cost much more.
Old Jul 7, 2010 | 10:26 AM
Matt93SE's Avatar
STFU n00b!
17x8"
Miket2006
Mar 1, 2021 03:55 AM
knight_yyz
Nov 1, 2015 01:34 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
