Maxima wont start!
Old Jul 6, 2010 | 12:13 PM
robsterzallan`'s Avatar
Maxima wont start!
I drove my car up on ramps, shut it off, and took the whole exhaust system out besides the manifold and O2 sensor. I welded a new exhaust out of 4 inch piping, away from the car, not under it, and put it all in. When i went to drive the car off the ramps, it wouldent start. So i messed around for a bit trying to figure it out and what not. First, the fuel pump wouldent start up when you turn the key on, then i checked for spark, none, so i checked the coil, and it was bad, so i replaced it. still had all the problems, so i turned to the computer, but the computer lights dont even turn on when i turn the key on. So i have no idea what the deal is. Bad computer? but i dont know what could of happened to it? i recently chiped the IAT sensor, but that couldent hurt the computer could it? any help would be great. Thanks!
Old Jul 6, 2010 | 12:22 PM
BenStoked's Avatar
Jesus was a Zombie.
have you checked your fuses, yet?
Old Jul 6, 2010 | 01:38 PM
yea all fuses are good,
Old Jul 7, 2010 | 01:41 PM
shiloh51933's Avatar
Did you go threw everything that you disconnected first to see if you forgot something. If the car drove up the ramps then it's obviously something you did. Check all your sensors.
Old Jul 7, 2010 | 02:53 PM
BenStoked's Avatar
Jesus was a Zombie.
okay, lets start from the beginning:
remove the "chip"
you turn the key; does the engine turn over, or not?
fuel pump wasn't humming; did you fix that, or is it still not starting?
no spark; how did you test the coil?
computer; did you verify you put it in diagnostic mode first?
Old Jul 7, 2010 | 03:09 PM
Matt93SE's Avatar
STFU n00b!
http://www.youtube.com/watch?v=G-tCIRJH9p0
Old Jul 7, 2010 | 03:12 PM
Greeny's Avatar
¯\(°_o)/¯
Originally Posted by Matt93SE
Old Jul 7, 2010 | 06:38 PM
Only thing i did was took the O2 sensor out, and it tested good.
Old Jul 7, 2010 | 06:40 PM
remove the "chip"
Yes the motor turns over with and without the chip, and it was running fine with the chip before the exhaust job. I cant figure out whats wrong with the fuel pump, i tested resistance on the coil, and when you turn the key on the computer lights should light up anyways, but yes no matter what you do the computer lights dont even turn on.
Old Jul 7, 2010 | 07:15 PM
BenStoked's Avatar
Jesus was a Zombie.
went, double checked, you are right.
I am still suspect of a blown fuse; does anything else not work?
Old Jul 7, 2010 | 09:51 PM
Um on the turning directional lever, you spin the end once for gauge lights and parking lights, and then 2 clicks for headlights. The gauge lights and parking lights dont turn on on the first click, but the head lights work on the second click, but thats about it, other then the fuel pump and computer, but i tested for the power to the coil, and when you turn the key on the coil gets power, but dont send out spark. What fuses should i check? Ill double check tomarrow. All inside and all under the hood, i dont know of any others.
Old Jul 8, 2010 | 04:41 AM
Greeny's Avatar
¯\(°_o)/¯
Check the big fusible links in the black box under the hood....
1-6.... look at the silver strip inside the top window of the fuse..replace the one thats broken.
Old Jul 8, 2010 | 08:26 AM
Yea i know that, ill check now.
Old Jul 8, 2010 | 10:22 PM
Nope all fuses are good. I have no idea other then the ECU. what do you think?
Old Jul 9, 2010 | 09:23 PM
Anyonee have any other ideas?
Old Jul 9, 2010 | 09:26 PM
chrome91's Avatar
are all of your grounds good?
Old Jul 9, 2010 | 10:45 PM
ColombianMax's Avatar
have you tried getting rid of the 4 inch exhaust and installed the stock size yet?
So let me get this straight.
-Battery is fully charged?
-Engine does crank but does not start?
-Does it put put or make a sputter sound as it "attempts" to start like a backfire?
-Have you checked the ignition cables to make sure they're all connected at the distributor as well as on the coil?
-When engine turns over, does it crank REAL fast compared to before?
Old Jul 9, 2010 | 11:11 PM
LvR's Avatar
LvR
You totally honest when saying you never welded on the car itself?
Seen many a fried ECU as a result of bad welding practices................
Old Jul 10, 2010 | 08:16 AM
1991Maxima1991's Avatar
^^^ Yup welding on the car WHILE the Battery is hooked up could verywell result in a fried ecu, from what ive experianced it will ruin the alternator aswell....im just wondering about the 4" exhaust???? y 4 inches rly? 3 is for turbo's wdf is 4 for? Anyway i would put it back to the way it was before you tinkerd with it and see what happons...Still think ur ecu is toast tho..
Old Jul 10, 2010 | 09:00 AM
LvR's Avatar
LvR
The exhaust is not the problem ............... you can remove the whole thing and the motor must still start and run.
Old Jul 10, 2010 | 10:59 AM
Yes, i redid all of them when i had the other problems with it
Old Jul 10, 2010 | 11:01 AM
Fully charged.
It cranks but dont start
No, just turns over like theres nothing there.
Yes everything is tested and good.
Nope turns over regular.
and why would i putt the other exhaust on?
Old Jul 10, 2010 | 11:02 AM
i swear on my life i dident weld on the car, im not the dumb. and is all but welds, theres no way its even posible under the car
Old Jul 10, 2010 | 11:03 AM
Just made sure i wouldent have any back pressure
Old Jul 10, 2010 | 11:04 AM
Yupp ive had the car running before with no exhaust, or O2 sensor.
Old Jul 10, 2010 | 01:12 PM
Just doesn't make any sense, car was running, you drove up ramps and now no start. I would check junk yards for ECU, you can find used ones for cheap sometimes and install that one to see if you ride will start up. It sound like that is where your problem is coming from if everything checks out like you say. Even if you didn't fry it by welding, it still might have overloaded with all the mods your trying to run on her and fried ECU. I would look there, it can't hurt.
Old Jul 10, 2010 | 09:28 PM
maxmaxima91's Avatar
No restriction here.... haha... At the time i could do 4 inch cheaper than 3.5..
Old Jul 11, 2010 | 10:25 AM
Haha, yea you bought yours for your car, i just bought the pipe and welded it together, then just put two 90 degree bends in it and ran it strait back and took the sway bar out.
Old Jul 11, 2010 | 10:26 AM
Thats what im thinkin, but if thats the problem as soon as i plug in the new one that will be junk also?
Old Jul 11, 2010 | 12:36 PM
So we've narrowed it down to there being AIR, and FUEL, just simply no SPARK... is that correct?
Old Jul 11, 2010 | 01:33 PM
khemraj1999's Avatar
the ECU lights should turn on when you put the ignition on..
sounds like a fried ECU? ..no crank signal receiving..no spark?
Old Jul 11, 2010 | 02:45 PM
Your not gonna fry another ECU, you fried it during whatever you were doing. Make sure all fuses/relays are good, disconnect your battery terminals and cover them with something that can't pass electrical current and install used ECU. There cheap enough used at most junk yards, if you've checked everything else like you said then your ECU is DEAD. Just try it, if it don't work or let's say you do fry it, then bring back to wreck yard and tell them it don't work. Good wrenching.
Old Jul 11, 2010 | 02:53 PM
chrome91's Avatar
yep just get a JY ECU, the junkyard here will let you bring anything back but you just get credit
Old Jul 11, 2010 | 03:08 PM
+1 does he have to match any numbers on the ECU? or just any 3rd gen works?
Old Jul 11, 2010 | 04:03 PM
chrome91's Avatar
i would imagine is its from the same engine/tranny its fine. i dont even think the tranny matters because some people with turbo VG's use the Z31 turbo ECU, and Z31 of course have VG30E but a different tranny
Old Jul 11, 2010 | 04:05 PM
No no.. made with my two hands
Old Jul 11, 2010 | 08:29 PM
Your exhaust looks very nice and it tucks up under there well, i also like your crossmember up front did you make that your self? looks nice and tough...
Old Jul 11, 2010 | 09:00 PM
Thanks.. yea i made everything myself. it double as a down pipe/flex guard/speed bump destroyer.. its 1/2 inch solid steel and wins against everything it hits. Sorry robster... i didnt mean to thread jack.
Old Jul 11, 2010 | 11:28 PM
I believe the ECU is year specific... I remember I once thought my ECU was bad on my 93GXE and I did some research and only a certain ECU was compatible. Make sure you do your research before spending money or wait til' someone else chips in with more info...
Old Jul 12, 2010 | 12:39 AM
sup_mario's Avatar
Are you sure that fuses are still good?
