Generally this isn't good..
irony lol. i got a crapload of engine work done on my 3rd gen a few days ago, and he inspected everything. i guess my front swaybar is completely gone, and the endlinks and stuff are gone. he said my front tires are wobbling half a inch and they have bad wear
and he said one of the parts i need you can only get from junkyard cars now
Buying Pass. Strut cuz that's been dead for awhile..now I have a job to fix the stuff I need..
Gonna get the MOOG Endlinks, and thinking about the Tie rod end bushings..I wanna replace them both but I'm thinking if I should just replace the Tie rods as well while i'm at it...and hopefully I didn't wallow out the hole where the endlink goes into the control arm because now I can physically move the endlink back and forth..which isn't a good sign.
http://www.courtesyparts.com/maxima-...94-c-1610.html
Should I even bother with the list of things wrong with my max...lol
- Oil leak (underbody coated with oil build up (especially passenger side)
- Power Steering leak (leak on Rack&Pinion) -- at times during autocrossing the powersteering will fail then engage again almost simultaneously
- TIRES!!!
- Passenger Strut
- EGR Valve sticks open..so especially when the engine is warming up, it surges with speed increasing
- Catalytic converter might be bad...
- Swaybar Endlinks
- Tie Rod end bushings
- Lower control arm bushing(s)
- Power lock timing unit
- Rear Pass. side window motor fails almost every time it's set down
- Transmission mounts need replacing
- Rear Spoiler is literally hanging on by just one mount..all the rest have rusted/dry-rotted out
- TIRES!!!
- Passenger Strut
- Swaybar Endlinks
I would love for that list to be at cero or close to..
but that probably won't happen..as I'm really saving up towards another car..I'm just trying to make sure my daily is SAFE to drive
Ordering parts when I get paid so I should be updating this thread soon hopefully. Just hope I can get 2 days off in a row to fix it so I can have one day to fix (one back up day in case something goes wrong and/or get it aligned!)
looks like that pass outer tie rod is shot. look at the angle of the top compared to the stud going through it. I'd check it for play. if you can feel any play, then it's done. I bet that thing is toasted just from the angle in that photo. But I've been wrong before (not often, but it happens!
g'luck!
)g'luck!
i have a power steering leak as well, but the guy said its not bad enough to replace everything to just keep an eye on the fluid level. somebody (guessing the previous owners mechanic) mixed coolant with tapwater as well, and the calcium in the water and stuff frigged up my radiator a bit
my door lock timer died a year and a bit ago but i havent fixed it yet lol. i'll check Courtesy to make sure i can get all the parts, if i can just fix my suspension and the leaks i'll be set
there are a lot of parts you can get used or from parts cars.
I think for a little money you can send James your door lock timer and he will send you a fixed one.
You can get a used window motor or regulator and take a chance on that.
are you sure it's your EGR and not your IACV? Those can be cleaned out.
Eh, the regulator/motor thing isn't as much of an issue since most of the time I don't have someone sitting back there
and well my idle doesn't surge or dump or anything like that but when I apply part throttle and accelerate (again it's most common when the vehicle is warming up -- I usually let it idle for at least 3 minutes before I go anywhere, even in this warm climate) but after I've been driving for a little while it doesn't do it as frequently or even at all. It's like it'll increase, flat spot, increase, flat spot (all while i'm applying the same amount of throttle) and my TPS is good so I know it's not that
Question:
I noticed the Tie rod ends on my car are much diff. than the MOOG ones
Moog set which does not carry the same curve in the middle of the tie-rod end..would that affect vehicle characteristics since it's more "direct" ?
I somewhat doubt it but just wanted to ask before I bought them.
Also on the funny note, this Nissan sales guy think the VE30DE engine is a myth (saying Nissan only have VG and VQs for Maximas) and VG30E have Dual Overhead Cams.
Learn the Maxima or don't say anything at all.
Me too tho the point, I need a new power steering pump, hoses, and it leaked all over my lower control arms. Another CC charge on the MAX
Question:
ive gots a suspension question. my control arms, end tie rods, and ball joint came in the mail today, but the thing is i want to replace those and the struts/springs in one whack. i should have had the struts a month and a half ago but every Tokico seller has waited a week or two before telling me they never had the set in stock. im down to the last option of dropping $750 shipped on a set of Koni's, could those take a 2" drop on a 3rd gen? thanks
you want the gamber to go more negative as the suspension compresses, more positive as it extends, to compensate for body roll and shear forces against the sidewall. if you watch a pickup truck or Ford panel van with blown shocks on the highway, you can actually wtatch the wheels camber in and out as the nose bounces over the road. That's cuz they have dual wishbones in front, with a short arm at the top and a long arm at the bottom, so the top arm pulls in at a faster rate than the bottom arm, hence the camber change. see how that would work on this setup? upper control arm angles in alot faster due to being shorter, and pulls the top of the knuckle inward toward the frame as the bottom pushes out.
however since on struts, the top is a 'fixed point', all you have to adjust the camber with is the control arm at the bottom. and as soon as the control arm starts pointing up... you start gaining positive camber under compression which is massively massively bad for cornering and stability, and just as bad for tire wear because you are basically riding on your sidewalls around turns. And i can tell you, based on crawling underneath nc90gxe's car with intrax springs, that his control arms are already pointing waay up on a 1.7" drop. you can see it in this pic.. you gain negative camber up until your control arm (yellow on the left, yellow/teal on the right) goes level (just like they show in the pic), then once it starts pointing up, you go back towards (and into) positive camber (not shown in pic) as the cosine of the arm (ie distance horizontal to body) decreases as theta (angle) increases.
about the only way to combat that and have negative camber even under compression is to add a huge amount of caster angle (which isn't very common on FWD cars), a huge amount of kingpin inclination (which you are kindof limited by your strut tower location on that one, plus it hurts turning radius after a certain point) or a huge amount of static negative camber (not so great for tire wear when you're going straight)
Got the new endlinks and strut in!
Rides soooooooooo much smoother! Been awhile since I've felt that in my car.
Pics of process. (coming soon) It was kinda stupid that factory ones were 14mm and 12mm then the MOOG ones were in standard size for the lock nuts and we could "use" a 15mm but it was slightly off.
Bought a drill for my job, Harbor Freight, and it did pretty good on helping us compress the spring but couldn't get the job done to initially get the strut to knuckle bolts undone..had to crack em loose then zip it out
Rides soooooooooo much smoother! Been awhile since I've felt that in my car. Pics of process. (coming soon) It was kinda stupid that factory ones were 14mm and 12mm then the MOOG ones were in standard size for the lock nuts and we could "use" a 15mm but it was slightly off.
and when are you getting an e30 in real life instead of just having it as your avy?
it was definitely not intentional..I didn't take as close of an observation of things before deconstruction as I should have..but I needed the car driveable by today so I could make it to work so I just put it on there.
Also, I'm getting an E30 or a 240 in a couple months. Gonna slap some tires on the max and call it good so I can officially start saving again. I was neglecting a much needed fix because of lack of funds..now that won't be the case.
should have included the link, these Koni's
