full gas tank leak? an oxidation?
Old Dec 13, 2001 | 08:46 AM
tmc's Avatar
tmc
91' GXE
The tank leaks when it is full. Possible diagnosis and am I able to fix it or should I bring it in?
Also, anyway to get rid of oxidation on the side molding?
Thanks a million,
John
jcanetta@hotmail.com
Old Dec 13, 2001 | 08:59 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: full gas tank leak? an oxidation?
Originally posted by tmc
91' GXE
Thanks a million,
John
filler neck may be rusting away...see if u had your recall done.
oxidation..if it's light..get some polishing compound and start rubbing. if it's heavy..respray will be needed.
Old Dec 13, 2001 | 01:43 PM
eric93SE's Avatar
Yeah there is a TSB on the filler neck
It said that crud and/or salt can build up under the rear tire and corode the filler neck. Nissan should replace it for free!
Old Dec 13, 2001 | 02:50 PM
Brian_TII's Avatar
It could also be one of the rubber hoses that connects to the tank. I had the vent hose go bad on mine. Similar symptoms to what you are descibing.
Good luck,
Brian Murray
87 RX-7 Turbo II (w/mods)
89 Maxima GXE (daily)
Old Dec 13, 2001 | 05:08 PM
Dave S's Avatar
Re: Yeah there is a TSB on the filler neck
Check out nhtsa.gov for info on the recall.
BTW - I had the same problem as Brian (leaky vent hose).
Old Dec 14, 2001 | 09:35 AM
tmc's Avatar
tmc
It was the filler neck!
Thanks guys. The filler neck was cracked!
Old Dec 14, 2001 | 09:38 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: It was the filler neck!
you're welcome
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
NERDJUSTBNME
Sep 30, 2015 03:20 PM
cruce91
Sep 20, 2015 10:23 AM
dcam0326
Sep 7, 2015 07:26 AM
