caliper rebuilding
Old Jul 24, 2010 | 09:18 PM
Hatmanafro's Avatar
caliper rebuilding
so im wondering what it takes to rebuild a caliper on a 3rd gen.
does it consist of just cleaning and changing the dust boot and caliper piston seal?
and also anybody know of a good quality rebuilding kit or can just any suffice?
i kinda need to rebuild my drivers side caliper.. its a leaking a lil DOT 3 and thats no good. i think its the seal.
Old Jul 24, 2010 | 09:39 PM
LvR's Avatar
LvR
Rebuild is a simple seal and boot replacement after you have stripped the caliper .................... problem is you don't know if its going to be worth your time till you stripped it and see how much rust has occurred on the piston's surface
Old Jul 24, 2010 | 09:48 PM
Hatmanafro's Avatar
ohh..
never thought of that.. idk thought. i dont think the caliper is that bad.
any links to a kit?
Old Jul 24, 2010 | 09:55 PM
LvR's Avatar
LvR
Originally Posted by Hatmanafro
ohh..
any links to a kit?
If the boot and/or seal needs replacement you can be sure to find either dust/dirt or rust on the piston surface that damaged the seal.
I am in South Africa and generally are unable/unwilling to buy kits on-line because of cost ............ some of our local US brothers will maybe chip in later with a suggested source I guess
Old Jul 24, 2010 | 11:22 PM
Hatmanafro's Avatar
oh alright man. and i understand you now. nuthin a lil cleaning cant fix
Old Jul 25, 2010 | 06:51 AM
Matt93SE's Avatar
STFU n00b!
parts stores sell rebuild kits, but dealer kits aren't that expensive either. they even come with instructions (just like in the FSM).
Old Jul 25, 2010 | 09:49 PM
Max_5gen's Avatar
I was unable to find source for pistons so before buying the kit which includes only seals check your pistons first and don't bother if their surface is already rusted. If you try to clean/polish that you might create a leak as a result as you'd decrease diameter of the piston. I'd rather buy rebuilt calipers instead if the pistons are rusted.
Old Jul 28, 2010 | 09:25 AM
Hatmanafro's Avatar
while i was on 'vacation' i rebiult the caliper.
its really simple and the caliper piston looked really good. still smooth and shiny..
replace the seal and the dustboot in like 10 or 15 minutes.
when it was time to put the piston back in the bore it was kind of a PITA but u just have to play with it until it slides in.
Old Jul 28, 2010 | 09:31 AM
BenStoked's Avatar
Jesus was a Zombie.
not work safe
glad you got it all back together. is it installed, yet?
Old Jul 28, 2010 | 09:51 AM
Hatmanafro's Avatar
lulz..
yeah man its all back into place. i should have done a flush.. buuuutttt.. i was kinda lazy. didnt feel like bleeding everything..
i sorta forgot to take pics..
Old Jul 28, 2010 | 05:04 PM
Matt93SE's Avatar
STFU n00b!
Lube the seal with brake fluid before putting it in. may burn a little bit at first, but the feeling goes away pretty quick. just be sure to wash afterwards.
Old Jul 28, 2010 | 07:59 PM
Hatmanafro's Avatar
oh yeah i lubbed everything up..
it was really tight so even with the lube you had to have it perfectly straight down and in.
are we still talking about a caliper....
James92SE
142
Jan 2, 2024 09:23 AM
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
BkGreen97
Apr 2, 2016 05:47 AM
Pied
Sep 26, 2015 03:29 PM
