Need To Raise Idle (Please Respond Quick)
Old Dec 16, 2001 | 02:26 PM
pimpofbrooklyn's Avatar
Hi Guys,
Just wanted to know how to raise the idle of my car a tad. It's idling kind of low the past couple of weeks. I am really dumb when it comes to under the hood. Can someone please tell me where the screw is and where is the Throttle body? I know the screw is near the throttle body but I don't know where the throttle body is (How Sad). A quick response would be really appreciated. Thanks a million.
Old Dec 16, 2001 | 10:17 PM
Rancid90SE's Avatar
Re: Need To Raise Idle (Please Respond Quick)
Originally posted by pimpofbrooklyn
Hi Guys,
its ok Newbie my answer will only be any good to you if you have a VG..the thing with the 2 round things with the cables connected goin to the back of the engine bay..well the thing that the round things are connected to...that your throttle body,the screw may be covered with a rubber cap,maybe not..too late and cold to go look at my engine...hope it helps,explained it in as easy terms as i could
Old Dec 21, 2001 | 05:42 PM
andy90se5spd's Avatar
a little late. but check this thread out. i had some instructions there.
http://forums.maxima.org/showthread....djust+and+idle
Old Dec 22, 2001 | 05:17 AM
KITT's Avatar
There is a small screw driver hole in the computer under the dash behind the centre bit where the transmission shifter is located. I did mine there. Adjust the screw till ur idle is where U want it.... Hope this works..
Old Dec 22, 2001 | 10:10 AM
male's Avatar
IDLE
I thought you adjust the idle at the AAC valve (VG30), screw under rubber cap on right side of valve?
aw11power
Oct 10, 2021 04:57 AM
Unclejunebug
Apr 2, 2016 05:42 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
