Used Or New
Old Oct 4, 2010 | 12:02 PM
Augustus Maximus's Avatar
Used Or New
It's apparent that after a certain time the VE coilpacks starts to arc, causing all kinds of driveability problems. From severe bucking, stalling, inability to idle and lost of throttle response all because one coil was no good. Which brings me to question why replace old with old. Is it purely a cost factor.
Old Oct 4, 2010 | 01:24 PM
shiloh51933's Avatar
You already know, if you can go new then go new, sometimes you find a good used 1 and never get the new 1 cause she's running good w/used 1. If you got the dough then just cop the new joint.
Old Oct 4, 2010 | 01:46 PM
Just snatched one up from the Zone...I'll be done with the firewall side next week, then on to the next . It's an Hanshin part...probably the same thing the dealer sells for considerably more.
Old Oct 4, 2010 | 01:54 PM
maximo018's Avatar
They are $56 at Auto Zone. And they are OEM even though they come in a duralast box. They have the Nissan logo on them.
Old Oct 4, 2010 | 02:21 PM
$65.00 here in Connecticut .
Old Oct 4, 2010 | 02:27 PM
James92SE's Avatar
2 VE's are better than one!
$336 isn't bad I guess for all new coil packs
Old Oct 4, 2010 | 09:10 PM
maximo018's Avatar
No it isn't. I replaced all 3 on the left. Now I need to replace the right side.
Old Oct 15, 2010 | 06:53 AM
Four down two to go...
Old Oct 15, 2010 | 06:11 PM
maximo018's Avatar
how happy I am for you. Tomorrow I get to put in another tranny and replace clutch master cyl. oh boy...
Old Oct 16, 2010 | 05:52 AM
I have a tranny and rear main seal to put in next year, looking at EMPI axles to go with it. I also have a spare master and slave from the donor car. What clutch and PP you plan on using.
Old Oct 16, 2010 | 08:46 PM
Cliff Clavin's Avatar
Way out West
My only word of advice is to mark them if you just buy 1 or replace 1 with a diffferent one.
I had a bad one and the accidentally mixed it in with the rest, so I have a bunch I am not sure if they are good or not. When I took the extra set from my parts car, I have them in their own box in my garage marked "from parts car."
Old Oct 17, 2010 | 05:26 AM
I had two bad ones the rest are good, but I'm replacing them anyway. Call it a fresh start.
Old Oct 17, 2010 | 07:14 AM
maximo018's Avatar
ACT Street clutch stage 1 organic disc. And yesterdays install was kool until I found out that my raxle passngr side axle was broken. along with my new defective slave cyl.
Old Oct 18, 2010 | 04:29 AM
Sorry to hear that man.
Old Oct 18, 2010 | 05:35 AM
maximagician's Avatar
can a ignition coil on these ve30 be bad even if it passes the ohms test per fsm?
Old Oct 18, 2010 | 07:19 AM
I have two that says so. The coil is basically a high ratio step up transformer and what you're testing is just the primary coil. How can a ohm test show if the secondary coil is arcing across itself or into the the transformer core or if the rectifier started conducting reverse voltage. Under such conditions back E.M.F. is fed into the primary coil which is fed back into the power transistor. And if I'm correct the VE power transistor is monolithic mean it's multiple transistors formed on the same substrate much like an IC so interaction occurs. Mine was so bad even though it ohmed out good that sometimes I heard it arcing out just before the engine died while flying down the highway.
