Brake & Battery Light Illuminating sporadically
Old Nov 18, 2010 | 07:41 PM
AM_BlackMax's Avatar
Fox Body FTW
First off, I didn't search before I posted this but this seems like a unique problem.
Drive-ability is not effected whatsoever but whenever I increase my speed both of the lights (Brake & Battery) flash randomly and the faster I accelerate the faster they illuminate until they look almost like a solid.
I'm gonna check the connections and what not but just wanted run this by to see if this was somewhat of a "common" problem
Old Nov 18, 2010 | 07:59 PM
BenStoked's Avatar
Jesus was a Zombie.
alty.
bad/loose connection(s)?
(3yrs+12k posts, ya didn't search? n00b)
seriously, never heard of them flashing like that. vid?
Old Nov 18, 2010 | 08:01 PM
chrome91's Avatar
yep check the alternator
Old Nov 18, 2010 | 08:06 PM
Crusher103's Avatar
change that alternator.
Old Nov 18, 2010 | 10:37 PM
elusivemax93's Avatar
alternator connectors or just alternator is dead. More then likely alternator is dead though
Old Nov 19, 2010 | 07:58 AM
Augustus Maximus's Avatar
It happened to me last winter. It's the alternator not the connections. Driveability is not affected because you got a good battery, but start her up and drive around with the battery disconnected and see what happens. Time to spend on her again...merry christmas.
Old Nov 19, 2010 | 09:02 AM
Fox Body FTW
I just bought a new alternator in the spring because my other one died on me
Voltage checks out fine.
I will get a video up soon
Old Nov 19, 2010 | 10:34 AM
Voltage doesn't mean anything if your amperage isnt putting out. Our amps the VE alternators make if it is a VE is 95 amps.
Old Nov 19, 2010 | 02:39 PM
93SCMax's Avatar
98 SE
If you are sure your alternator from spring is ok, double check your alternator belt. Check tension and belt condition. Belt shouldn't show any "break-outs". I only use OEM belts. Make sure it isn't slipping under load or higher rpm.
Old Dec 27, 2010 | 08:53 PM
Fox Body FTW
Super late response and apologies with getting no video up (sourcing a computer has been difficult - let alone to up load videos on) but that's exactly what it was..the belt was just loose.
Problem solved Thank you gentlemen.
We can "close" this thread, thanks
Old Dec 28, 2010 | 12:04 PM
Ur a bad man . When you drive an older car it's good to develop a habit of opening the hood and looking around every once in a great while. You just might see that something that needs attention.
Old Dec 31, 2010 | 08:11 PM
Fox Body FTW
Well I'm still learning my way around the maintenance routines so it was something I just so happened to overlook. I couldn't notice it with the car running because it's not like it's bam right in my face but I will know from now on so that's the main thing.
tsi6001
Oct 3, 2022 10:23 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
Nismo_Guy89
Aug 24, 2015 09:49 PM
Samedi
Aug 13, 2015 04:05 PM
Superbform
Aug 11, 2015 08:10 PM
