temp guage moves at its own will..........
Old Dec 15, 2010 | 05:42 AM
G3Karl's Avatar
If I mash the gas or hit a hard bump my temp guage will drop then eventually come back to normal.
Heat works fine and the cooling system is topped off and not leaking.
Is this a bad coolant temp sensor?
Thanks!
Old Dec 15, 2010 | 06:39 AM
LvR's Avatar
LvR
Bad guage imo?
Terminals/wiring bad?
Old Dec 15, 2010 | 08:58 AM
DennisMik's Avatar
I'm thinking you may have wiring issue, loose connection, probably at the engine. Check your engine mounts and make sure that the engine isn't bouncing around.
Old Dec 15, 2010 | 09:11 AM
YearOfTheGus's Avatar
The wire on my temp sending unit was loose, caused this same problem. It's located on the passenger-side of the engine, follow the upper radiator hose and you should find it.
Old Dec 15, 2010 | 05:45 PM
chrome91's Avatar
i had the same thing with my GXE cluster, tach would do nothing or thrash 3/4 of the time, and the temp gauge would work half the time and the other half just shoot up to H or limp at C, try swapping clusters
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
