The Rear Caliper
Old Jan 8, 2011 | 12:55 PM
Augustus Maximus's Avatar
The Rear Caliper
What is the difference the 89-90 and 91-94 rear caliper. Is it the entire assembly or just the torque member. Is there a difference between the ebrake cables?
Old Jan 8, 2011 | 03:23 PM
James92SE's Avatar
2 VE's are better than one!
I know for sure the ebrake cable mounting mechanisms are different (ie, even if the calipers are the same you couldn't put a 93 caliper on an 89 and be able to hook up the ebrake cable and vice versa). Newer style is a hook and loop cable and the okder style is a throttle cable dowel type setup
Old Jan 8, 2011 | 07:06 PM
Aaargh ...I was tryin to avoid messing with the cables. Luckily I still have the 92se donor . Well since this car has the 90se strut I might as well upgrade to the Z rotor.
Old Jan 8, 2011 | 07:34 PM
tripleGmax's Avatar
im pretty sure the entire assembly is diff. got me when i had a froze caliper and used one off a '90
Old Jan 9, 2011 | 12:37 AM
maxinout93's Avatar
Yes they are different, I noticed like someone said above that the parking brake cable hook-up is different on 89-91 and 92-94s. Also one seems to be a bit larger than the other.
matts95max
Apr 23, 2025 10:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
bbsitum
Sep 11, 2015 04:55 PM
beerman1378
Sep 8, 2015 02:19 PM
