Brake Mod
Old Jan 17, 2011 | 08:39 AM
Augustus Maximus's Avatar
Brake Mod
Anybody ever tried the G35 dual piston caliper with 2004 Maxima rotor on the 3rd gen...it seems like a great combo.
Old Jan 17, 2011 | 09:43 AM
GRNMAXDMON's Avatar
Im sure it should be the same thing as the Z32 combo that we have just that they look sleeker.
Old Jan 18, 2011 | 09:07 AM
I found a pair of 6th gen caliper with brackets for $60 so I'm going with that.
Old Jan 19, 2011 | 01:55 PM
James92SE's Avatar
2 VE's are better than one!
So you're doing 6th gen calipers and rotors?
Old Jan 19, 2011 | 08:58 PM
6th Gen calipers and rotors up front and Z31 rotors in the back. I have almost everything I need already.
Old Jan 23, 2011 | 02:01 PM
txsilverado1's Avatar
Keep us up to date. Sounds like it could be a cheap and effective mod.
Old Jan 23, 2011 | 02:34 PM
dj tes's Avatar
need pics when done!
Old Jan 23, 2011 | 02:47 PM
elusivemax93's Avatar
Just do z32 BBK I'm doing that but instead of Z32 calipers I'm gonna be using skyline gtr 34 calipers.
Old Jan 23, 2011 | 05:12 PM
kyles2ndmax's Avatar
anybody know if you swap the drum break set up for the stock disk set up......... know alot of time the manufacture will cast all the mounting holes what you get just depends on what you pay at the lot
Old Jan 23, 2011 | 07:00 PM
Just hit the jy and find a se and take the spindle and strut housing assembly as well as calipers and be ready to have fun with brake lines and the emergency brake cable since the rear calipers have built in emergency brake assembly.
Old Jan 24, 2011 | 04:09 AM
Too late I bought everything already...come Spring I'm replacing the entire steering system, drivetrain, all calipers, rotors and ebrake cables. Then it's engine time.... Pics?
Old Jan 24, 2011 | 04:16 AM
shiloh51933's Avatar
Since your all on the topic of brake upgrades I wanted to post in...I'm looking at wheels right now for my 3rdgen and want to upgrade the brakes mostly for looks. My braking system is in excellent shape but wouldn't look that good with some of the wheels I've wanted to buy. I'm looking to do the easiest(meaning easiest parts available) mod possible. Is there a particular write that maybe I missed? Appreciate any suggestions.
Old Jan 24, 2011 | 08:17 AM
Haven't got to the BBK yet dont have alot of hp needing a better braking system yet plus my calipers I'm going to get have to come all the way from japan. If I'm not mistaken brembo used to offer a skyline gtr BBK for the third gens but that also was like eight years ago when I first got into maximas.
Old Jan 24, 2011 | 09:26 AM
http://forums.maxima.org/3rd-generat...en+bbk+writeup
Nice cheap mod, the extra money is going into tightening up my biatch. Just picked up a set of low mileage 4th gen injectors over in the 4th gen classified, next up is all the O rings and insulators, fuel injection hoses and the (14) clamps.
Old Jan 24, 2011 | 02:29 PM
Jeff92se's Avatar
I'm needing a caw
But if on a budget, the 6th gen swap is probably the cheapest. But any upgrade should include a bigger rotor no matter what calipers you use. that seems to be the one factor in better braking (vs trying to use a caliper with more piston area)
Old Jan 24, 2011 | 05:09 PM
BigRek718's Avatar
Thanks alot guys, this kinda helped; 6th gen brake kits go for around how much?
Old Jan 24, 2011 | 07:32 PM
When I do my BBK I'm going to buy 2004 maxima aftermarket rotors with matts z32 calipers bracket extenders and nissan skyline GT-R 34 calipers.
Old Jan 25, 2011 | 12:33 AM
maximo018's Avatar
Good luck finding those brackets, they don't have nor make them anymore.
Old Jan 25, 2011 | 12:38 AM
Dude does it look like it bothers me? I have people that cnc machine so that is no worry to me. lol I have a spare parts car so I have the spindles to take off and take them to my cnc machinist. Matt's brackets aren't one of a kind.before matt jeff was making them.
Old Jan 25, 2011 | 05:02 AM
Cost me like $150 for everything shipped. Just need to go to the hardware store and grab a few bolts. It's a nice simple mod that let's you wear 12.6" rotors and beef up your brakes without breaking the bank.
Old Jan 25, 2011 | 04:04 PM
Yo A M, you seem like you have quite a bit of experience with modifying our brakes so I'm directing this question to you or anyone else also. Anyone ever hooked up Q45 brake calipers/rotors/pads to a 3rdgen?
Old Jan 25, 2011 | 04:23 PM
Jeff92se's Avatar
I'm needing a caw
Mine are alot less complicated than Matt's. I'm not sure why you are going out of your way to use Japanese calipers when the 3 piston 300Z 30mm versions are just fine.
And you can put Q45 calpers on. With stock Q rotors that are milled down, with my brackets and 13" cobra rotors.
Old Jan 25, 2011 | 07:03 PM
maximo018's Avatar
I know Jeff did. I have a set. I found out recently that the two kits are completely different. One for 13" rotors and the other is 6th gen rotors. One extends the caliper out further than the other kit. But you probably know this already seeing how you've done your research. This one some how slipped by me.
Old Jan 25, 2011 | 08:49 PM
GRNMAXDMON's Avatar
Can you confirm this??? I need a new set of brackets.
Old Jan 26, 2011 | 12:15 AM
Jeff still have your templets you made way back when?
Old Jan 26, 2011 | 04:06 AM
Let me edit Jeff's post to answer you.
Originally Posted by Jeff92se
You can put Q45 calpers on with stock Q rotors that are milled down. Or you can put Q45 calipers with my brackets and 13" cobra rotors.
In other words...yes.
Old Jan 26, 2011 | 04:37 AM
Thanks, I asked cause somebody was selling there Q45 brake set up and was thinking about using. Changing the rear drums out is gonna suck though, it's weird that my Max came with all the options possible for that year but all wheel disc. I've replace everything possible on them and got premium pads but the rear drum won't look right with a set of after market rims.
Old Jan 26, 2011 | 08:44 AM
Jeff92se's Avatar
I'm needing a caw
I still sell the BBK brackets to use with the 13" cobra rotors.
Old Jan 26, 2011 | 08:53 AM
Get a 1989-91SE rear strut assembly, 1992-94SE ebrake cables and calipers, 1986 Z31 rotors...
Old Jan 26, 2011 | 09:27 AM
Reizy's Avatar
Another option: http://forums.maxima.org/3rd-generat...e-upgrade.html
I know at least one other member has done this but has yet to comment on it.
Old Jan 26, 2011 | 11:58 AM
See jeff my thing is will your brackets allow for the z32 calipers to fit correctly over the 2004 nissan maxima rotors becuase the 2004 are more hub centric then mustang cobra rotors. Less movement where the wheel studs go through the holes in the rotors. In other words less slop in gap between wheel stud and rotor stud hole. anyways how much you selling your brackets for?
Old Jan 27, 2011 | 09:08 PM
maximo018's Avatar
Emailed them the other day and talked to Matt who both told me they don't. Matt is gonna try to look around his stuff to see if he can find me some, but thats it.
Old Jan 27, 2011 | 09:12 PM
maximo018's Avatar
If you have a GXE that would've been one of the things you would'nt have received. SE's only.
Old Jan 27, 2011 | 09:17 PM
maximo018's Avatar
No they won't. I already tried that route. The caliper only grips the edge of the 6th gen caliper.
Old Jan 27, 2011 | 10:33 PM
Well then ill just go the route of getting my skyline gtr 34 calipers and have a machine shop make me my brackets that work with gtr calipers. Not a big deal to me really.
Old Jan 28, 2011 | 09:23 AM
Jeff92se's Avatar
I'm needing a caw
Nope. If you use the cobra rotors redrilled to the Nissan stud size, the fit it good. Automax sells the cobra rotors this way. $60 shipped
Old Jan 28, 2011 | 10:40 AM
James92SE's Avatar
Eh, I've been running Jeff's BBK for 5-6 years now with non-re-drilled rotors. I haven't had any problems at all in terms of it being "sloppy". Yeah I mean the stud holes are a tad bigger than the studs but it's made absolutely tangible difference in terms of braking ability or braking feel
Old Jan 28, 2011 | 10:44 AM
Jeff how much you selling BBK bracket sets for?
Old Jan 28, 2011 | 11:03 AM
Jeff92se's Avatar
I'm needing a caw
$60 shipped
Old Jan 28, 2011 | 12:40 PM
$60 shipped
Sweet good price I'll be hitting you up once I get ready for my BBK upgrade
