Inner tires wasting.
Old Feb 12, 2011 | 10:07 AM
JRS89MAX's Avatar
Whats up ppl. Just noticed my front 2 tires are wasted in the inner side. Both of them evenly. Any ideas before I start buying pieces. Steering doesnt shake when im going 65 or better. Little puzzled.Thanks
Old Feb 12, 2011 | 10:58 AM
Augustus Maximus's Avatar
Yeah start buying pieces and get an alignment when you done.
Old Feb 12, 2011 | 03:40 PM
shiloh51933's Avatar
You got pics? Is your ride lowered or do you have after market wheels or bigger wheels than stock? As much info as you can provide will be helpful.
Old Feb 12, 2011 | 04:04 PM
JRS89MAX's Avatar
I just have all factory. 205/65/15 With regular MAX rims. All stock.
Old Feb 12, 2011 | 04:27 PM
krashkid0305's Avatar
Check ball joints and strut mounts those 2 points take care of most of your camber angle. If those are tight then send it out for an alignment.
Old Feb 12, 2011 | 07:04 PM
Matt93SE's Avatar
STFU n00b!
What he said ^^^^^^.
On a stock suspension, it's going to most likely be worn suspension parts- tie rod ends, ball joints, control arm bushings, strut mount, something like that.
jack the car up and shake around on the thing- see what's loose. If you find play in anything, then there's your problem.
The big issue is the suspension is 20 yrs old on this car, so everything is likely worn/mostly worn out and ready for replacement.
figure out what's broken... replace it, then get an alignment.
If you don't know how to swap the stuff out or how to check the suspension (there's a bazillion threads out there on how to check it out.), then it may be best to take it to a decent alignment/suspension shop, and they will usually do a free inspection of the suspension and give you a repair estimate before you commit to anything.
Old Feb 20, 2011 | 07:12 PM
JRS89MAX's Avatar
Will do. Will give feedback on the out come.
Old Mar 5, 2011 | 05:25 PM
JRS89MAX's Avatar
Well I got new tires. While they jacked the car looked and shooked the tires to see if there was any slack. The tire guy also checked. Nothing major.Anyway went for an alignment today. Guy didnt bother. He said I needed lower ball joints. No charge. Manage to put 1 ball joint today was to late. Had to be the lower ball joints because it was the inner tire that was wasted. Will do the other tommorrow or this week.
Will inform how it works out.
Old Mar 6, 2011 | 06:46 AM
maxinout93's Avatar
yeah reminds me that Ive got to replace my driver side ball joint, along with the cv joint, may as well do them both since im gonna have the thing torn down. Where can I get a sealed ball joint. The last one I got from autozone required lots of grease to fill. and I had grease all over the thing.( probaly because I forgot to put the things on top and bottom of the boot) lol.
Old Mar 6, 2011 | 08:30 AM
GAMERA30's Avatar
From: Long Beach, CA is where i live. Queens NYC is always home.
check front end .. if u happen to get an alignment, you can see whats gone bad as well form looking at the specs.
Old Mar 6, 2011 | 09:51 AM
road_warrior05's Avatar
I got mine from Napa and I didnt have any problems with it. Not a lot of grease was required either
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Garrettz459
Sep 28, 2015 02:50 PM
