Climate Control Swap...
Old Feb 21, 2011 | 11:11 PM
Infam0usMax's Avatar
I have a "auto" climate control that doesnt work I got to the JY once a week and I find nothing so questions is how hard is it to swap out the auto for a manual?... pictures will help get better understanding... and please dont post a comment about reading other threads because I did search before posting this thanks.
Old Feb 21, 2011 | 11:23 PM
Hectic's Avatar
Don't swap to manual. I can fix whatever issues you're having, whether it's the control unit or fan speeds.
Old Feb 22, 2011 | 06:00 AM
GRNMAXDMON's Avatar
Huh, im actually having the same problems on mine but its been years that ive had it like this where the display will just dim away but at night you can barely see the screen. Anyway i can get it fixed?
Old Feb 22, 2011 | 06:36 AM
Hectic's Avatar
The best way to go about the climate control repair is via exchange with a refundable core deposit. I have prefurbished units ready to go. That way you're not stuck without heat or A/C during turn around time; since the controls still function although you can't see the display. Anyone in need, just send me a PM.
Old Feb 22, 2011 | 06:17 PM
89boostedmax's Avatar
what all is involed in swapping from man to auto climate control.
Old Feb 23, 2011 | 10:58 AM
All I asked was how to swap it guys... not looking to repair or anything else I need The A/C to work and in order to do that I need to know what setting is on. This auto cc has no light but all the buttons do work its just the screen doesn't show anything...
Old Feb 23, 2011 | 12:05 PM
DMad8724's Avatar
swapping it to manual climate control is gonna be the biggest waste of time compared to having hectic put a working display in the mail
and if thats all you wanna know check out craigs acc how to and do the opposite of that? yeah way too much work. Hectic FTW
Old Feb 23, 2011 | 01:08 PM
shiloh51933's Avatar
I have climate control and very happy with, at times the screen dims and makes difficult to see in the daytime. There is a control that dims it by mistake but it works and I swapped out with new control box but the solar sensor is out of whack.
Old Feb 25, 2011 | 12:47 AM
Went to The JY bought a "new" one and it all works just need to change out some bulbs just found out that they are 5mm LED's... so thanks guys hopefully this thread will help someone else.
Old Feb 25, 2011 | 05:46 AM
Hectic's Avatar
Are the edges of the display dimming? If it's a consistent dim over the entire display, then that's just the auto dim feature which occurs when the parking/head lights are on. Even when the brightness switch is to the max, it's still not as bright as when lights are off. If one wanted to, one could disconnect the illumination wire so one could have full brightness at all times
Thanks for the plug I assume you've wired up the dash and seen the pretty lights since your last PM?
Old Feb 27, 2011 | 11:54 AM
DMad8724's Avatar
oh they are magical
the swap between mph and kmh is flawless too
only problem is the LEDs i bought are single SMD leds that only point outwards so my illumination isnt as solid as an incandescent...may just go with an amber bulb
btw im still waiting on my ACC unit to arrive in the mail...maybe youll have to fix that too
Old Feb 28, 2011 | 05:13 AM
[quote=Hectic;7947064]Are the edges of the display dimming? If it's a consistent dim over the entire display, then that's just the auto dim feature which occurs when the parking/head lights are on. Even when the brightness switch is to the max, it's still not as bright as when lights are off. If one wanted to, one could disconnect the illumination wire so one could have full brightness at all times
It's not the auto dimming when Parking/headlights are turned on...when illuminated correctly it is very bright, bright enough to see perfectly on a sunny day. It's back and forth with this happening, I've even tried swapping another unit in to no avail. I'm not sure what it is, somebody said something about the solar dial.
Old Mar 2, 2011 | 08:08 PM
92gxe/cg2's Avatar
Too alleviate the "hot spots" caused by the LEDs you can just sand their surface lightly so that it looks scuffed or frosted evenly all over. Then the lights reflected in many different angles. Doesnt always work 100% but I have redone all of the interior including the radio and climate controls and they are lit almost perfectly even all over. Although I am not sure what the LEDs you bought look like, i soldered resistors and LEDs i got cheap on ebay in, as long as they have a lense you can sand it should help alot.
Old Mar 13, 2011 | 12:43 AM
so i got my 5mm bulbs today and they don't fit! im guessing the holes in tha back are for 3mm or 2-1.5mm bulbs?
tarun900
19
Dec 20, 2021 06:57 PM
gavin68
Sep 18, 2021 12:36 PM
tseng1023
Oct 15, 2015 08:30 AM
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
