Upgrading Fuel Injector Connectors
Old Aug 21, 2011 | 09:32 AM
  #41
CMax03's Avatar
Originally Posted by Augustus Maximus
Napa belt...ever try oem?
Oem 93-94 timing kit next time....gotta check alignment of sprockets/tensioner!!!!!
Old Aug 21, 2011 | 01:01 PM
  #42
Porky's Avatar
Amazing photos Cmax, thanks
Old Sep 4, 2011 | 02:48 PM
  #43
CMax03's Avatar
Check out what I'm working on for the mean time....a 2002 Saturn Vue with a DOHC 3.0L V6 (Opel/GM) and a broken timing belt due to all the oil leaks etc and 100% Owner Neglect and AutoShop regret! Wow guys our engine are in a class all by themselves (VG, VE, VQ, VH, VK, etc) and this engine is a freaking joke as far as component placement!
Old Sep 4, 2011 | 04:12 PM
  #44
maximo018's Avatar
What else you got left? Looks like your almost done finally.
Old Sep 4, 2011 | 09:52 PM
  #45
CMax03's Avatar
I have both Heads installed with cams, cam seals, cam sprockets, exhaust manifolds, ECU, and timing tensioners.......I have to glue in all the seals on the valve covers, LIM, UIM, install the spark plugs, coil packs, engine mt, serpentine belt plug in allthe sensor/connectors and crank that bi+ch! I finished today with all the timing gear installed but not the belt.....pretty much just the intake system left (LIM + UIM).....
Old Sep 6, 2011 | 12:21 AM
  #46
CMax03's Avatar
Somemore Saturn going back together (I can almost see the light):
Old Nov 6, 2011 | 09:25 PM
  #47
tweak's Avatar
Thanks a ton for this thread, I'm in the process of doing this on my 89. One of the fuel injectors died on me a few days ago, and the connector practically disintegrated when I tried to get the plug unstuck from the corrosion. Figured it'd be a good idea to do the upgrade since I'll have the intake taken apart and be replacing the injectors anyways.
I found a nice 94 at a junkyard, but one of the allen bolts on the intake plenum stripped out so I've still got a bit of work if I'm going to be able to actually pull this off without waiting for another batch to hit the yard.
Old Nov 7, 2011 | 07:10 PM
  #48
tweak's Avatar
The nice one got mangled between then and now (somehow they physically broke the intake plenum...) but I pieced together parts from some other cars on the yard. Only problem is 2 of the injectors on the rails I got are bad, and a 3rd is a VE/VQ injector. Would it be better in the long run to just go ahead and replace all 6 with new ones, since the other 3 might fail in the near future anyways?
Old Nov 7, 2011 | 11:58 PM
  #49
maximo018's Avatar
Save yourself the time and frustration and just go all new.
Old Nov 8, 2011 | 01:56 PM
  #50
tweak's Avatar
Yeah, I think that's what I'll do. It's money I don't really need to spend right now, but it'll pay off in the long run.
Old Nov 8, 2011 | 09:56 PM
  #51
maximo018's Avatar
yeah and you won't have to kick yourself every time you have to go back in there to change one.
Old May 1, 2012 | 03:00 PM
  #52
shiloh51933's Avatar
Originally Posted by Maxkiller
I bought new square clip connectors to fit 89-91 off ebay and soldered them into the loom. Haven't had any corrosion on the new injectors. Vg30
Do you remember who you bought these connectors from on ebay?
Old May 2, 2012 | 10:04 PM
  #53
CMax03's Avatar
Maybe a Kevlar timing belt is what I'll need.....
http://www.importpartspro.com/poensustiivg.html
Problem turned out being a hydraulic lifter that broke it's mushroom tappet and jammed my forward head's cam from rotating and sheared my timing belt cogs.....I'll more than likely replace all 12 new lifters with newer lifters since I idled them for about 5-10 minutes to bleed the air out of them since they weren't submerged in oil like I did when I originally installed them 5000 miles ago,....I actually had them stored upside down and the lack of letting them soak in oil for a day or two caused the premature failure!
Old May 2, 2012 | 10:39 PM
  #54
maximo018's Avatar
Well at least you realized your mistake vs some of the rest of us go off assuming and guessing what our culprit had to be.
Old May 3, 2012 | 09:09 AM
  #55
It figure's that I have the off centered index slot injectors and everyone only has the centered index slot. Looks like I'm going to have to notch out the centered index slot to fit the connector onto the injector prongs.
Old Sep 30, 2012 | 03:19 AM
  #56
Porky's Avatar
Don't forget to pre-lube the cam and lifters with the ZDDP concentrate. There's a better one out there than the Comp Cams. The AC Delco EOS I have only been using on the regular oil changes after the break-in, since the concentration is too low for break-in. For me personally, I drizzled a whole container on the new camshaft and coated the whole lifter in the comp cams also. I didn't use the regular Moly assembly lube camshaft paste (although I probably should have), instead went for the Comp Cams.
I'm wondering if the failure was because the cam and lifters had no critical zinc, in that first initial start up. I always thought the lifters, if there was air in them, after a few minutes they would simply purge the air, but they would never do damage really.
Regarding Lube which might have been the culprit-I've heard from some engine guys, that its risky not using the camshaft assembly paste, if the engine is going to sit for some time, or it gets rotated before it is fired up on break in, then sits for a while, as the liquid primer (Comp Cams) that some people use (like me), can have a tendency to run off the lobes, because it's really light. Then, when operator goes to fire up engine, for that first critical start, the camshaft gets damaged immediately.
Did you check the cam lobes, if the ruined lifter damaged the camshaft? If you have a wiped lobe, its probably going to damage any new lifter you put in that position, which may warrant replacing the camshaft on that head too, I don't know.
Just some cam tips for you, regarding the VG.
Old Sep 30, 2012 | 05:43 PM
  #57
CMax03's Avatar
No damage to cam lobes nor bearing surfaces but it did break the cam nose and dowel pin where the sprocket sets....So I'll need another cam and that was my Nissan Motorsport (Isky) Cam that cost about $500 for the set...I might purchase another set and go to 1mm oversized valves and Higher rpm JWT springs while at it....Next lifters will be soaked in oil for a week prior to installation! I did this the first time i installed them and there was no noise (tapping) and I didn't do that when I reinstalled them this time and the tapping at idle last for about 15 minues and the cam broke in about 40 miles after reassembly! I'm good I'll get this whipped! This car was fast as hell so getting another set of performance cams is mandatory.
Old Oct 2, 2012 | 02:14 PM
  #58
Porky's Avatar
I'm curious, if the timing belt snaps on our 93-94 VG engine (or it slipped in your case), is there immediate damage to the valves, as in they smack the piston heads? Meaning valve replacement at the least, or even worse off, valve guide replacement?
Also part 2 of this question, as some one here may have experience. Is there a way to replace the intake and exhaust valve stem oil seals WITHOUT removing the cylinder heads? I've heard of some method of connecting compressed air to the spark plug hole, which will hold the valve up, but how do you get the springs to compress to remove the keepers?
Old Oct 2, 2012 | 02:56 PM
  #59
emeka44's Avatar
Newbie here just reading and trying learn... I WILL be back
Old Oct 2, 2012 | 11:09 PM
  #60
maximo018's Avatar
To the first part of your question they usually snap. His slipped once because the stud for the tensioner broke. This time around was because his cam broke (rare).
As for the second question I didn't know that it was possible for one to remove them without taking off the head. If it hasn't been done and only talked about then that leans more towards it can't be done.
Old Oct 3, 2012 | 08:01 AM
  #61
CMax03's Avatar
Usually it will bend about 2-4 valves per head but sometimes people got lucky and no damage was seen.....I'll remove my head cause I'll probably install 1 mm oversize valves and Jwt hi rpm springs....
Old Oct 3, 2012 | 07:13 PM
  #62
maximo018's Avatar
YAY! You gonna go Ferrera for your valves?
Old Oct 6, 2012 | 09:15 AM
  #63
CMax03's Avatar
sohe belt teeth (4"-5") was sheared off due to a lifter breaking and kamming the froont head cam which not only broke damaged my timing belt but also broke my Isky Cam sprocket face with the dowel pin....I'll need to purchase another set of Isky cams cause I don't think I can replace 1, they're a set....
Old Oct 7, 2012 | 01:58 AM
  #64
Porky's Avatar
CMax03, did you break this thing in properly, and what oil are you using. It's extremely rare for a lifter to fail like that.
Old Dec 3, 2012 | 07:42 PM
  #65
CMax03's Avatar
Well I did a mock fit using the LIM, fuel rail, and lower plenum inlet plate and I even used the later piece and port matched it to the LIM......I may modify my original inlet plate which needed some of the rib strengthens ground down!
Danny......I used the existing LIM, but had to install the later design adapter intake plate, later design fuel rail, later design injectors, upgraded injector cap hardware (allen head or hex head bolts), later model improved connectors subharness on fwd bank, splice in connectors on rear bank.....
Old Apr 25, 2014 | 09:29 PM
  #66
CMax03's Avatar
The cause was a lifter mushroom broke jammed the front bank cam, snapped the dowel pin out of the cam @ the cam sprocket and ate the teeth off my timing belt for about 6" and screwed up all mty beautiful work....it's almost 3 years and I finally ready to ressurrect my beast..with even more mods....
Old Apr 26, 2014 | 06:00 AM
  #67
DanNY's Avatar
Ad·min·is·tra·tor
Cmax...do you happen to have pics of the new injector connector..(the injector side)?
i saved up enough pennies to get the injectors...but wanted to make sure i get the right one.
Old Apr 26, 2014 | 10:13 PM
  #68
jbbons25's Avatar
I don't remember who posted this (think it was the wookie) but I saved the pic on my computer.
Old Apr 27, 2014 | 05:11 AM
  #69
DanNY's Avatar
Ad·min·is·tra·tor
thank you sir
Old Apr 27, 2014 | 11:16 AM
  #70
CMax03's Avatar
DanNY that's correct I confirmed it....
Old Apr 27, 2014 | 02:51 PM
  #71
Fatboy98maxima's Avatar
So how many pennies did it come out to? if you dont mind sharring ?
Old Apr 28, 2014 | 08:14 AM
  #72
DanNY's Avatar
Ad·min·is·tra·tor
looks like $480 for a set of JECS 550CC
Old Apr 28, 2014 | 03:15 PM
  #73
Maxpwer's Avatar
No turbo, no care!
Not a bad deal for side feeds, where are you getting them?
I had been looking for a good deal on larger flow injectors as well. Since top feed injectors are more common I thought I could find a modern injector with good flow rates for a reasonable price. The best deal I've found is the new Bosch EV14 injectors. A set of 6 is $339 for 550cc or 700cc from Deatschwerks. (Note the universal line has 3 different injector lengths, the "compact" 40mm injectors are the cheapest, and the larger ones may not fit) http://www.deatschwerks.com/products...-0065-6-detail
For a fuel rail you should be able to use almost any VQ35 fuel rail. I tried the stock one off a 350z and the injectors line up perfectly. You just need to make two brackets per rail to bolt it into your factory bracket hole. Alternatively, an aftermarket rail for a VQ35 would be a little more but easier to adapter to your return style fuel system vs modern VQ return less.
Just another option for those looking for cheaper injectors
Old Apr 28, 2014 | 07:03 PM
  #74
DanNY's Avatar
Ad·min·is·tra·tor
Five-o have the injectors. seems like their ebay listing is a little cheaper than their store.
i tried to get some info on them but i see a lot of mixed opinions. for the price i'm going to give it a shot and see. they gotta be better than the 370cc old style that i'm running now.
Old Oct 6, 2015 | 10:23 AM
  #75
ac max 92's Avatar
I realize im bumping an old thread but im curious if yourself or anyone would happen to know if there is any difference between the LIM between the 89-92 and the 93-94. Im just finishing up doing this upgrade but noticed the 89-92 injectors are longer than the 93-94 injectors so im wondering how much difference it will make being the 93-94 injectors wont go down as far into the LIM as the 89-92 injectors im wondering if this will actually maybe cause a slight loss in performance being the 93-94 injectors might partially spray into the walls/ports of the LIM but im not 100% because the tips are also different between the 89-92 and the 93-94 injectors. Im curious to know CMax if you happened to notice this or how the performance was using the existing LIM?
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
